Lisp to copy file if modified
sjdunn-2019
sjdunn-2019
Need someone better at lisp than me, trying to use lisp to copy a file from one location to another if date modified of source file is newer than destination file. Put some pieces together but doesn't quite work as expected. I think systime looks at date created for file vs date modified? Any suggestions?
(defun c:copyIfModified (/ sourceFile destFile sourceDate destDate)
  (setq sourceFile "N:\\CAD\\Details\\sample.dwt")
  (setq destFile "C:\\CAD\\Details\\sample.dwt")
  ;; Get the last modified date of the source file
(setq sourceDate (vl-file-systime sourceFile))
  ;; Check if the destination file exists
(if (findfile destFile)
    (progn
;; Get the last modified date of the destination file
(setq destDate (vl-file-systime destFile))
      ;; Compare the source and destination file dates
(if (/= sourceDate destDate)
        (progn
;; If the dates are different, delete original and copy the source file to the destination
(vl-file-delete destFile)
(vl-file-copy sourceFile destFile)
          (princ "\nFile copied1.")
        (princ "\nNo changes detected.")
    (progn
;; If the destination file doesn't exist, copy the source file to the destination
      (princ "\nFile copied2.")
  (princ)
paullimapa
@sjdunn-2019 Looks like your code just uses a not equal symbol which does not distinguish older vs newer:
According to the online manual, vl-file-systime does return last modification date.
The return vl-file-systime value is in a list with 7 or 8 items:
  • year
  • month
  • day of week
  • day of month
  • hours
  • minutes
  • seconds
So what you can do is compare each item <<depending on length of return list (nth 0 through nth 6) or (nth 0 through nth 7)> to see if the source file is newer than the destination.
Once you get a match where the source file has an item that is greater than the destination then you can stop the comparison and continue with the copy.
Paul Li
IT Specialist
@The Office
ronjonp
@sjdunn-2019
Use XCOPY or ROBOCOPY. Here's some lisp code I put together a while back.
sjdunn-2019
It took me a little while to get back at this plus doing a little testing. I ended up using the startapp option to run a batch file and used robocopy from within the batch file to copy modified files. The batch file is run when AutoCAD starts and this way I can modify the batch file as needed for additional files to update. Trying to keep it simple, thanks for the suggestions!
