LISP to Convert Ellipse to Polylines modification
Message 1 of 11
I've already found a LISP here in this forum that works pretty well for converting Ellipses into Light Polylines (not heavy 2D Polylines).
Here is the little routine:
(foreach x (mapcar 'cadr (ssnamex (ssget "X" '((0 . "ELLIPSE")))))
(ACET-GEOM-ELLIPSE-TO-PLINE x)
(entdel x)
(princ)
I'm running a major LISP that contains many others that comes back and aftwards this one. But this major LISP is stopping and not executing the next actions at the point of this Ellipse>Polyline LISP because of this error:
From my tests, this error only occours when there are no Ellipses in the drawing. So, anyone can help me modifying this LISP to check if there is Ellipses in the drawing before running the code itself, so maybe the rest of the LISP will work everytime?
Thanks a lot for any help.
Replies (10)
Message 2 of 11
john.uhden
I know nothing about your lisp routine, but if it is behaving the way you describe, then maybe don't call it unless there are ellipses in your drawing...
(if (ssget "X" '((0 . "ELLIPSE")))
  (load .......)
John F. Uhden
Message 3 of 11
It just worked as expected now! And YES, this LISP routine works like a charm to convert Ellipses to Polyline. Actually it's the best LISP I've found on the entire Internet to do this task in the simpliest manner possible. I was only trying to figure out how to make it execute only when there are Ellipses present in drawings. Your load ideia just made it work like a charm now! Thanks sir.
Message 4 of 11
ZJDevine07
Observer
Observer
Maybe this is something I haven't seen before, but how does this work??? Every LISP routine I've seen starts with....
(defun C: *your command* ()
Message 5 of 11
bill.kruder
any chance I could get a copy of this from you...would greatly appreciate it.
thnx,
-Bill
Message 6 of 11
_gile
Here's a way without using the Express Tools ACET-GEOM-ELLIPSE-TO-PLINE function.
The main routine which converts an ellipse or an elliptical arc into a polyline apriximation (same as PELLIPSE = 1):
;; EllipseToPolyline (gile)
;; Retourne une polyline (vla-object) qui est une approximation de l'ellipse (ou de l'arc elliptique)
;; L'ellipse source est conservée ou supprimée en fonction de la valeur de DELOBJ
;; Argument : une ellipse (vla-object)
(defun EllipseToPolyline (el    /  doc   cl    norm  cen   elv   pt0   pt1   pt2
                          pt3   pt4   ac0   ac4   a04   a02   a24   bsc1  bsc2
                          bsc3  bsc4  plst  blst  spt   spa   fspa  srat  ept
                          epa   fepa  erat  n
  (vl-load-com)
  (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))
        spc (if (= 1 (getvar 'cvport))
              (vla-get-PaperSpace doc)
              (vla-get-ModelSpace doc)
        cl   (and (= (vla-get-StartAngle el) 0.0)
                  (= (vla-get-EndAngle el) (* 2 pi))
        norm (vlax-get el 'Normal)
        cen  (trans (vlax-get el 'Center) 0 norm)
        elv  (caddr cen)
        cen  (3dTo2dPt cen)
        pt0  (mapcar '+ (trans (vlax-get el 'MajorAxis) 0 norm) cen)
        ac0  (angle cen pt0)
        pt4  (mapcar '+ cen (trans (vlax-get el 'MinorAxis) 0 norm))
        pt2  (3dTo2dPt (trans (vlax-curve-getPointAtparam el (/ pi 4.)) 0 norm))
        ac4  (angle cen pt4)
        a04  (angle pt0 pt4)
        a02  (angle pt0 pt2)
        a24  (angle pt2 pt4)
        bsc1 (/ (ang<2pi (- a02 ac4)) 2.)
        bsc2 (/ (ang<2pi (- a04 a02)) 2.)
        bsc3 (/ (ang<2pi (- a24 a04)) 2.)
        bsc4 (/ (ang<2pi (- (+ ac0 pi) a24)) 2.)
        pt1  (inters pt0
                     (polar pt0 (+ ac0 (/ pi 2.) bsc1) 1.)
                     pt2
                     (polar pt2 (+ a02 bsc2) 1.)
                     nil
        pt3  (inters pt2
                     (polar pt2 (+ a04 bsc3) 1.)
                     pt4
                     (polar pt4 (+ a24 bsc4) 1.)
                     nil
        plst (list pt4 pt3 pt2 pt1 pt0)
        blst (mapcar '(lambda (B) (tan (/ b 2.)))
                     (list bsc4 bsc3 bsc2 bsc1)
  (repeat 2
    (foreach b blst
      (setq blst (cons b blst))
  (foreach p (cdr plst)
    (setq ang  (angle cen p)
          plst (cons
                 (polar cen (+ ang (* 2 (- ac4 ang))) (distance cen p))
                 plst
          plst (cons
                 (polar cen (+ ang (* 2 (- ac0 ang))) (distance cen p))
                 plst
  (setq pl
         (vlax-invoke
           spc
           'AddLightWeightPolyline
           (apply 'append
                  (setq plst
                         (reverse (if cl
                                    (cdr plst)
                                    plst
  (vlax-put pl 'Normal norm)
  (vla-put-Elevation pl elv)
  (mapcar '(lambda (i v) (vla-SetBulge pl i v))
          '(0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16)
          blst
  (if cl
    (vla-put-Closed pl :vlax-true)
    (progn
      (setq spt  (vlax-curve-getClosestPointTo pl (vlax-get el 'Startpoint))
            spa  (vlax-curve-getParamAtPoint pl spt)
            fspa (fix spa)
            ept  (vlax-curve-getClosestPointTo pl (vlax-get el 'Endpoint))
            epa  (vlax-curve-getParamAtPoint pl ept)
            fepa (fix epa)
            n    0
      (cond
        ((equal spt (trans pt0 norm 0) 1e-9)
         (if (= epa fepa)
           (setq plst (sublist plst 0 (1+ fepa))
                 blst (sublist blst 0 (1+ fepa))
           (setq erat (/ (- (vlax-curve-getDistAtParam pl epa)
                       (vlax-curve-getDistAtParam pl fepa)
                    (- (vlax-curve-getDistAtParam pl (1+ fepa))
                 plst (append (sublist plst 0 (1+ fepa))
                              (list (3dTo2dPt (trans ept 0 norm)))
                 blst (append (sublist blst 0 (1+ fepa))
                              (list (k*bulge (nth fepa blst) erat))
        ((equal ept (trans pt0 norm 0) 1e-9)
         (if (= spa fspa)
           (setq plst (sublist plst fspa nil)
                 blst (sublist blst fspa nil)
           (setq srat (/ (- (vlax-curve-getDistAtParam pl (1+ fspa))
                            (vlax-curve-getDistAtParam pl spa)
                            (vlax-curve-getDistAtParam pl fspa)
                 plst (cons (3dTo2dPt (trans spt 0 norm))
                            (sublist plst (1+ fspa) nil)
                 blst (cons (k*bulge (nth fspa blst) srat)
                            (sublist blst (1+ fspa) nil)
        (T
         (if (< epa spa)
           (setq plst (append
                        (if (= spa fspa)
                        (cdr (sublist plst 0 (1+ fepa)))
                        (if (/= epa fepa)
                 blst (append
                        (if (= spa fspa)
                          (cons
                        (sublist blst 0 fepa)
                        (if (= epa fepa)
                          (list (nth fepa blst))
           (setq plst (append
                        (if (= spa fspa)
                          (sublist plst fspa (1+ (- fepa fspa)))
                                (sublist plst (1+ fspa) (- fepa fspa))
                 blst (append
                        (if (= spa fspa)
                          (sublist blst fspa (- fepa fspa))
                          (cons
                                (sublist blst (1+ fspa) (- fepa fspa))
                        (if (= epa fepa)
      (vla-delete pl)
      (setq pl (vlax-invoke spc 'AddLightWeightPolyline (apply 'append plst)))
      (foreach b blst
        (vla-SetBulge pl n B)
        (setq n (1+ n))
  (or (zerop (getvar 'delobj)) (vla-delete el))
  pl
;; Ang<2pi
;; Retourne l'angle, à 2*k*pi près, compris entre 0 et 2*pi
(defun ang<2pi (ang)
  (if (and (<= 0 ang) (< ang (* 2 pi)))
    ang
    (ang<2pi (rem (+ ang (* 2 pi)) (* 2 pi)))
;; 3dTo2dPt
;; Retourne le point 2d (x y) d'un point 3d (x y z)
(defun 3dTo2dPt (pt) (list (car pt) (cadr pt)))
;; Tan
;; Retourne la tangent de l'angle
(defun tan (a) (/ (sin a) (cos a)))
;;; SUBLIST Retourne une sous-liste
;;; Arguments
;;; lst : une liste
;;; start : l'index de départ de la sous liste (premier élément = 0)
;;; leng : la longueur (nombre d'éléments) de la sous-liste (ou nil)
(defun sublist (lst start leng / n r)
  (if (or (not leng) (< (- (length lst) start) leng))
    (setq leng (- (length lst) start))
  (setq n (+ start leng))
  (while (< start n)
    (setq r (cons (nth (setq n (1- n)) lst) r))
;; K*BULGE
;; Retourne le bulge proportionnel au bulge de référence
;; Arguments :
;; b : le bulge
;; k : le rapport de proportion (entre les angles ou les longueurs d'arcs)
(defun k*bulge (b k / a)
  (setq a (atan B))
  (/ (sin (* k a)) (cos (* k a)))
Two commands.
EL2PL : to convert a selection  of ellipses or elliptical arcs into polylines
PELL : to draw "on the fly" ellipses or elliptical arcs aproximations (polylines)
;; EL2PL (gile)
;; Convertit ellipses et arcs elliptiques en polylignes
;; Les objets source sont conservés si la variable DELOBJ = 0,
;; supprimés sinon.
(defun c:el2pl (/ *error* fra acdoc ss)
  (vl-load-com)
  (defun *error* (msg)
    (if (and (/= msg "Fonction annulée")
             (/= msg "Function cancelled")
      (princ (strcat (if (= "FRA" (getvar 'locale))
                       "\nErreur: "
                       "\Error: "
                     msg
    (vla-endUndoMark acdoc)
    (princ)
  (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (if (ssget '((0 . "ELLIPSE")))
    (progn
      (vla-StartUndoMark acdoc)
      (vlax-for e (setq ss (vla-get-ActiveSelectionSet acdoc))
        (EllipseToPolyline e)
      (vla-delete ss)
      (vla-EndUndoMark acdoc)
  (princ)
;; PELL (gile)
;; Dessine "à la volée" une approximation d'ellipse ou arc elliptique (polyligne)
(defun c:pell (/ *error* ec pe do old ent)
  (vl-load-com)
    (if (and msg
                       "\nErreur: "
                       "\Error: "
                     msg
    (setvar 'cmdecho ec)
    (setvar 'pellipse pe)
    (setvar 'delobj do)
    (princ)
  (setq ec  (getvar 'cmdecho)
        pe  (getvar 'pellipse)
        do  (getvar 'delobj)
        old (entlast)
  (setvar 'cmdecho 1)
  (setvar 'pellipse 0)
  (command "_.ellipse")
  (while (/= 0 (getvar "cmdactive"))
    (command pause)
  (if (not (eq old (setq ent (entlast))))
    (progn
      (setvar 'delobj 1)
    (EllipseToPolyline (vlax-ename->vla-object ent))
  (*error* nil)
Gilles Chanteau
GileCAD
GitHub
Message 7 of 11
john.uhden
Was that request meant for me? What, I actually did something right?
John F. Uhden
Message 8 of 11
bill.kruder
many thnx...I'll give it a shot
cheers,
-Bill
Message 9 of 11
john.uhden
@_gile 's code is as lengthy as he is smart.
Back when, I had simply considered rebuilding the ellipse from its geometry with PELLIPSE set to 1, but that may not help if the ellipse had been broken or trimmed.  I never looked any further into that.  I am guessing that there may be a way to retrieve the ellipse's start and end points and break the new pellipse at the same points.  I dunno.
John F. Uhden
Message 10 of 11
_gile
Thanks for the compliment, @john.uhden.
The above code also works with elliptical arcs ("retrieve the ellipse's start and end points").
Gilles Chanteau
GileCAD
GitHub
Message 11 of 11
eng.khaledabdelkarim
