LISP to - Connect line to base point of a block
nkamphui
Message 1 of 31
nkamphui
Hi all,
Is there a LISP that connects lines to the base point of a block? See attached pictures.
  • Lisp
Replies (30)
Message 21 of 31
hak_vz
(defun bbp ()(trans (cdr(assoc 10 (entget(car(entsel)))))0 1))
Copy this line above and past into a console and hit <enter>
This creates function (bbp). You can copy (bbp) in clipboard and paste it when needed.
And then select  connecting line end point i.e point you have to connect to block base point and move its handle.
When asked for new point paste or type (bbp) and hit enter
It asks you to select a block, and when selected it return its base point. So line and will move to that position.
Before you receive some better code you may use it and finish your work. Remember, Acad is drafting program  so changing 100 block shouldn't be a problem at all.
Miljenko Hatlak
Message 22 of 31
ВeekeeCZ
This works quite well for 3dpolylines.
BUT not with lwpolylines - if there is one, you need to unselect its block! See HERE  what I mean.
(vl-load-com)
(defun c:FixPlineToBlock ( / s i e o c lst-b lst-p)
  (if (setq s (ssget '((0 . "POLYLINE,INSERT"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    o (vlax-ename->vla-object e))
      (if (= "INSERT" (cdr (assoc 0 (entget e))))
	(setq lst-b (cons (cdr (assoc 10 (entget e))) lst-b))
	(setq lst-p (cons (cons o (progn
				    (setq c (reverse (vlax-get o 'Coordinates)))
				    (list (nth 2 c) (nth 1 c) 0)))
			  lst-p)))))
  (if (and lst-b lst-p)
    (foreach b lst-b
      (setq lst-p (vl-sort lst-p (function (lambda (p1 p2) (< (distance b (cdr p1)) (distance b (cdr p2)))))))
      (vlax-put (caar lst-p) 'Coordinates (append (reverse (cdddr (reverse (vlax-get (caar lst-p) 'Coordinates)))) b))
      (setq lst-p (cdr lst-p))))
  (princ)
Message 23 of 31
pbejse
@nkamphui wrote:
If its not don't worry about it. 😊
Message 24 of 31
nkamphui
Thanks for the reply. @ВeekeeCZ solution worked best for me.
Message 25 of 31
stevor
And Autolisp probably could save time, maybe 99%+,
by doing them all at once.
One way could be to define a search distance, like 3
Drawing Units, if the DUs are by cm, from an insert
 point of an INSERT, ie, 'block,  to find the closest 'pipe,'
using the ssget "c" function.
Then modify that pipe object to match the insert pt,
with the entmod function.
S
Message 26 of 31
nkamphui
Thankyou very much, works perfect! Transformed all lines to 3D polylines without issues. Only lines that are perfectly straight dissappear when executing this LISP. But i can do those by hand. Thanks again!
Message 27 of 31
ВeekeeCZ
... or pair it the other way around. For each pline end point search for the closest block insertion point. But I guess the way it is now is good enough.
Message 28 of 31
pbejse
Now you see the rainbow  @nkamphui 🙂
Message 29 of 31
hak_vz
Where @ВeekeeCZ solution don't work you can apply this (Lwpoly) . I'm at work and don't have a time to code something like he did. My solution is single line function written "out of sleave". I'm glad that you received a solution to your problem.
Miljenko Hatlak
Message 30 of 31
ВeekeeCZ
The other way around without the need to unselect no-match blocks. Also added distance limitation.
(vl-load-com)
      (setq e (ssname s (setq i (1- i))))
			  lst-b))
	(setq lst-p (cons (cons (setq o (vlax-ename->vla-object e))
				      c (list (nth 2 c) (nth 1 c) 0)))
			  lst-p)))))
    (foreach p lst-p
      (setq lst-b (vl-sort lst-b '(lambda (b1 b2) (< (distance b1 (cdr p)) (distance b2 (cdr p))))))
      (if (< (distance (car lst-b) (cdr p)) 2.)
	(progn
	  (vlax-put (car p) 'Coordinates (append (reverse (cdddr (reverse (vlax-get (car p) 'Coordinates)))) (car lst-b)))
	  (setq lst-b (cdr lst-b))))))
  (princ)
Message 31 of 31
nkamphui
This works even better thanks!
