LISP TO Combine duplicate block definitions
sadishpaul
Message 1 of 23
sadishpaul
hi experts,
i need a lisp which can do the following
Say i have multiple Similar Geometrical Blocks but its block names are Different,
I would like to convert  them to same block name
BricsCAD has this option by default under the commend Overkill -Combine duplicate block definitions
I have attached a sample picture below
Kindly Help me out experts
regards,
Paul
  • Lisp
Replies (22)
Message 2 of 23
hak_vz
@sadishpaulTry with express tool BLOCKREPLACE (Express tools -> Blocks-> Replace block with another block). After you've replaced all blacks purge drawing.
Miljenko Hatlak
Message 3 of 23
3wood
Is there any special pattern in block names?
Message 4 of 23
sadishpaul
@hak_vz
But i will be having 100s of blocks in my drawings, so it’s difficult to do it manually
And next thing is my blocks may be rotated or mirrored
Message 5 of 23
sadishpaul
@3wood
no special patterns , it may be any name.
Message 6 of 23
sadishpaul
what exactly i require is similar to the below command in BricsCAD
Message 7 of 23
hak_vz
Assuming that there are two similar blocks Block1 and Block2 and you want to replace all instances of Block1 with Block2 retaining its scale and rotation, and that blocks have no attributes this may work. Just fill the list of block names to be changed. Test on file copy.
(defun c:replace_duplicate_block_definitions ( / block_replace_names ss i ent)
	(defun *error* (msg)
		(if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*"))
			(progn
			   (princ (strcat "\nOops an Error : ( " msg " ) occurred."))
		(if (and adoc) (vla-endundomark adoc))
		(setvar 'cmdecho 1)
		(princ)
	(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
    (vla-startundomark adoc)
	;Edit this list of block names to be changed
	;Add as many (existing_block_name wanted_block_name) Names are case sensitive
	(setq block_replace_names
			("Block2" "Block1")
	(setvar 'cmdecho 0)
	(foreach e block_replace_names
		(setq ss (ssget "x" (list (cons 0 "INSERT") (cons 2 (car e)))))
		(setq i -1)
		(cond
			((and ss)
				(while (< (setq i (1+ i)) (sslength ss))
					(setq ent (entget (ssname ss i)))
					(setq ent (subst (cons 2 (cadr e)) (assoc 2 ent) ent))
					(entmod ent)
	(setvar 'cmdecho 1)
	(princ)
You can use function getblocks to collect in a list names of all blocks in file
(defun c:getblocks (/ adoc name lst)
	(vlax-for blk (vla-get-blocks adoc)
	;; Exclude model and paper spaces, xref and anonymus blocks
	(if (and  (equal (vla-get-IsLayout blk) :vlax-false)
			  (equal (vla-get-IsXref blk) :vlax-false)
			  (/= (substr (vla-get-Name blk) 1 1) "*"))
		 (setq lst (cons (vla-get-Name blk) lst))
	lst
Miljenko Hatlak
Message 8 of 23
Kent1Cooper
Are all the Blocks in the "before" category shown at 0° rotation?  So that in the "after" you want what was Block 3 to become an insertion of Block 1 at -45° rotation?  And Block 4 to become Block 2 at 45° rotation?  If that's the case, most Block-replacing routines [I have one, too] won't do what you want, because they replace Block insertions with a different Block name but retaining their rotations [and insertion points, and scale factors, and Layers].
Kent Cooper, AIA
Message 9 of 23
Sea-Haven
(setq block_replace_names '(("Block2" "Block1")
The issue is OP does not want to have to make this list, may not even know which ones match.
Bricscad has got smart and started adding functions that are not in Autocad as features, Blockify is another, they may be listening to their end users, rather than we know what you want.
Message 10 of 23
sadishpaul
@hak_vz
thanks for your codes, but as @Sea-Haven  mentioned,
I don’t know which one to match. , its difficult to find out in our drawings.
I want the Geometry to be compared automatically and replace it's instance matching the same rotation angle
In my drawings, the blocks will never be scaled. , it may be rotated or mirrored.
Message 11 of 23
sadishpaul
@Kent1Cooper
just to show that same blocks may be rotated , i have mentioned like that.
Message 12 of 23
ВeekeeCZ
I like THIS video. It's about the BLOCKIFY, but your issue is similar. It nicely shows how complex such a task is and how naive you are when you're asking to do this from us (and even for free).
Message 13 of 23
arinc_akkin
I dont know is there any1 who is fallowing this topic but i found a lisp routine a little close to this issue. The lisp changes desired blocks as source block . but block directions and insertation points are also changing. I need to keep blocks directions as it was.
(defun c:frto(/ ACTDOC COPOBJ ERRCOUNT EXTLST
       EXTSET FROMCEN LAYCOL MAXPT CURLAY
       MINPT OBJLAY OKCOUNT OLAYST
       SCLAY TOCEN TOOBJ VLAOBJ *ERROR* ASK)
  (vl-load-com)
  (defun *ERROR*(msg)
    (if olaySt (vla-put-Lock objLay olaySt)); end if
    (vla-EndUndoMark actDoc)(princ)); end of *ERROR*
  (defun GetBoundingCenter(vlaObj / blPt trPt cnPt)
  (vla-GetBoundingBox vlaObj 'minPt 'maxPt)
      (setq blPt(vlax-safearray->list minPt)
      trPt(vlax-safearray->list maxPt)
      cnPt(vlax-3D-point
      (list
            (+(car blPt)(/(-(car trPt)(car blPt))2))
            (+(cadr blPt)(/(-(cadr trPt)(cadr blPt))2))
            (+(caddr blPt)(/(-(caddr trPt)(caddr blPt))2)) ;_<<< Çàìåíèëè
            )))); end of GetBoundingCenter
  (setq extSet(ssget "_I"))
 (while (not (setq toObj(entsel "\n+++ Select source object -> ")))
   (princ "\nSource objects isn't selected!"))
  (if(not extSet)
    (progn
      (princ "\n+++ Select destination objects and press Enter <- ")
      (setq extSet(ssget "_:L")))); end if
  (if(not extSet)(princ "\nDestination objects isn't selected!")); end if
  (if (and extSet toObj)
    (progn
      (initget "Yes No")
      (setq ask (getkword "\nRemove destination object [Yes/No] <No>:"))
      (setq actDoc (vla-get-ActiveDocument(vlax-get-Acad-object))
      layCol (vla-get-Layers actDoc)
      extLst (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp
                     (mapcar 'cadr(ssnamex extSet))))
      vlaObj (vlax-ename->vla-object(car toObj))
      objLay (vla-Item layCol (vla-get-Layer vlaObj))
      olaySt (vla-get-Lock objLay)
     fromCen (GetBoundingCenter vlaObj)
      errCount 0  okCount 0); end setq
      (vla-StartUndoMark actDoc)
      (foreach obj extLst
        (setq toCen (GetBoundingCenter obj)
              scLay (vla-Item layCol (vla-get-Layer obj)));end setq
  (if(/= :vlax-true(vla-get-Lock scLay))
    (progn
    (setq curLay(vla-get-Layer obj))
    (vla-put-Lock objLay :vlax-false)
    (setq copObj(vla-copy vlaObj))
    (vla-Move copObj fromCen toCen)
    (_kpblc-ent-properties-copy obj copObj)
    (vla-put-Layer copObj curLay)
    (if (= ask "Yes")(vla-Delete obj))
    (setq okCount(1+ okCount))
    ); end progn
    (setq errCount(1+ errCount))
    ); end if
  ); end foreach
      (princ (strcat "\n" (itoa okCount) " were changed. "
    (if(/= 0 errCount)(strcat (itoa errCount) " were on locked layer! ")  "")))
      (vla-EndUndoMark actDoc)); end progn
    (princ "\nSource object isn't selected! ")
    ); end if
  (princ)); end of c:frto
*    Ôóíêöèÿ êîïèğîâàíèÿ íàñòğîåê ïğèìèòèâîâ
*    Ïàğàìåòğû âûçîâà:
*   source   ïğèìèòèâ-èñòî÷íèê (vla)
*   dest   ïğèìèòèâ-ïîëó÷àòåëü (vla)
*    Âûïîëíÿåòñÿ êîïèğîâàíèå âñåõ íàñòğîåê (êğîìå òî÷åê, êîîğäèíàò è ò.ï.), åñëè
* ıòî âîçìîæíî. Êîïèğîâàíèå ğàäèóñîâ äóã è îêğóæíîñòåé íå âûïîëíÿåòñÿ.
*    Êîíòğîëü è ïğåîáğàçîâàíèå ïàğàìåòğîâ íå âûïîëíÿåòñÿ.
*    Ïğèìåğû âûçîâà:
(_kpblc-ent-properties-copy (vlax-ename->vla-object (car (entsel))) (vlax-ename->vla-object (car (entsel))))
*    URL http://www.arcada.com.ua/forum/viewtopic.php?t=504&start=15
(defun _kpblc-ent-properties-copy (source dest)
 (foreach prop   '("Angle" "Layer" "Linetype" "LinetypeScale" "Lineweight"
        "Normal" "PlotStyleName" "Thickness" "Color" "Visible"
        "Closed" ;|"ConstantWidth" ; íå êîïèğóåòñÿ|; "Elevation" "LinetypeGeneration"
        "LinetypeScale" ;|"StartAngle" "EndAngle" ; íå êîïèğóşòñÿ|; "Alignment"
        "Backward" "Height" "ObliqueAngle" "Rotation" "ScaleFactor" "StyleName"
        "TextGenerationFlag"  "TextHeight"  "UpsideDown"  "AttachmentPoint" "BackgroundFill"
        "DrawingDirection"  "LineSpacingDistance" "LineSpacingFactor" "LineSpacingStyle"  "Width"
        "XScaleFactor" "YScaleFactor" "ZScaleFactor" ;| Viewport|; "ArcSmoothness" "CustomScale"
        "Direction" "DisplayLocked"  "GridOn" "LensLength" "ModelView" "ShadePlot" "SheetView"
        "SnapBasePoint" "SnapOn" "SnapRotationAngle" "StandardScale" "Target"  "TwistAngle"
        "UCSIconAtOrigin"   "UCSIconOn"     "UCSPerViewport" "ViewportOn")
 (if (and (vlax-property-available-p source prop)(vlax-property-available-p dest prop t))
  (_kpblc-error-catch
    '(lambda ()(vlax-put-property dest prop (vlax-get-property source prop))) nil)))) ;_ end of defun
*    Îáîëî÷êà îòëîâà îøèáîê.
*    Ïàğàìåòğû âûçîâà:
*   protected-function   — "çàùèùàåìàÿ" ôóíêöèÿ
*   on-error-function   — ôóíêöèÿ, âûïîëíÿåìàÿ â ñëó÷àå îøèáêè
(defun _kpblc-error-catch
       (protected-function on-error-function / catch_error_result)
  (setq catch_error_result (vl-catch-all-apply protected-function))
  (if (and (vl-catch-all-error-p catch_error_result) on-error-function)
    (apply on-error-function
      (list (vl-catch-all-error-message catch_error_result)))
    catch_error_result)) ;_ end of defun
(princ "\nType FRTO in command line")​
Message 14 of 23
hak_vz
@arinc_akkin wrote:
...... I need to keep blocks directions as it was.
Check the code posted under #7. It works the way you want. Alternatively selection of replacement blocks can be made by picking instead of change list. (explained in code).
Miljenko Hatlak
Message 15 of 23
arinc_akkin
Thanks for the response but both  lisps cant be run.
Secondly my block names arn not block1 block2 ... should i change the code according to block name in every new case?
The one i posted is like:
"Select source blocks" than select target blocks"
Message 16 of 23
hak_vz
Find in code above and change as you need
			("Block2" "Block1")
Miljenko Hatlak
Message 17 of 23
arinc_akkin
1. Lisp can't be run in ACAD.
2. I was asking about selection of source block than assign that block name to selected ones. This method doesn't require  adding names like Block1 Block2 etc. Thats not practical
Message 18 of 23
hak_vz
Maybe someone will find time to make it for you.  It's 3-4 lines of code to change.
Miljenko Hatlak
Message 19 of 23
arinc_akkin
Thank you for your time.
Message 20 of 23
hak_vz
Try this. Hope this is what you are looking for. All new blocks need to be inserted in drawing.
(defun c:replace_duplicate_block_definitions ( / block_replace_names ss i ent old new pick_block)
			(progn
		(princ)
	(defun pick_block (msg)
			(setq e (car(entsel msg)))
			(if (and (not e) (= (getvar 'Errno) 7)) (pick_block msg) e)
	(while
		(and
			(setq old (pick_block "\nSelect old block to be replaced >"))
			(setq new (pick_block "\nSelect new block >"))
	(setq block_replace_names (cons (list old new) block_replace_names))
	(if block_replace_names
			(setq ss (ssget "x" (list (cons 0 "INSERT") (cons 2 (cdr (assoc 2 (entget (car e))))))))
			(setq i -1)
			(cond
				((and ss)
						(setq ent (subst (cons 2 (cdr(assoc 2 (entget(cadr e))))) (assoc 2 ent) ent))
						(entmod ent)
						(princ "\n")
	(princ)
Miljenko Hatlak
