lISP to clean up drawing.
smallƑish
smallƑish
Greetings!
I m using all the below cmds one by one, is that possible to run all this with a single cmd.
DELCON >SELECT ALL
OVERKILL >SELECT ALL>OK
AUDIT>YES>
PURGE>PURGE ALL
REGENALL
SAVE.
Thank you
Kent1Cooper
Yes, and you will find a lot of very similar routines defined in this Forum, with some Searching, which should be easily modifiable for your particular needs.
Kent Cooper, AIA
paullimapa
you should be able to do this with script file written almost like the way you typed in your post.
read up on script creation ie my article here
Paul Li
IT Specialist
@The Office
WeTanks
GOOD!
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
