I am trying to get a lisp routine that will allow me to select a line, arc, polyline, etc. and have it 'reset' color, ,type, LWeight, and transparency to Bylayer, Elevation and thickness to 0, ltscale to 1,
Solved by Kent1Cooper. Go to Solution.
interesting but not what I am looking for. I want a lisp that when I select an element that already has a color, ltype, etc. that is not bylayer it will change all of the properties to bylayer.
How is that different from what the BYS command does, other than [as mentioned] it doesn't yet include Transparency?
I see now that there are several options and I missed your statement about using the BYS.
Thank you.
