Lisp to change properties of entire layers exception of item(s)
Message 1 of 8
I've searched through few forums and on-line tutorial to find my answer but could not find any solution.
I am looking for a lisp routine to change properties of all layers in a drawing except one(or a list of layer) .
I want to have that exceptional layer(s) name to be art of my lisp and not by command line input. i.e., all layers except layer "ABC" or "ABC" and "DEF".
Thanks and happy weekend
Replies (7)
Message 2 of 8
hmsilva
Hi Sam_RG,
something like this, perhaps
(vl-load-com)
(defun myfunctionname (lst)
    (vlax-for lay (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object)))
        (if (not (vl-position (vla-get-Name lay) lst))
            (progn
             ;; do the changes here...
; usage
; (myfunctionname '( "ABC" "DEF"))
Hope this helps,
Henrique
Message 3 of 8
thanks for quick answer but not clear to mate.
let say I want change color of  all layers  to "6". How it will be now?
Message 4 of 8
hmsilva
You're welcome, Sam_RG
But as you have said:
'I want to have that exceptional layer(s) name to be art of my lisp and not by command line input'
I thought you had already written that piece of code...
(vla-put-color lay 6)
Hope this helps,
Henrique
Message 5 of 8
Kent1Cooper
@Anonymous wrote:
....I am looking for a lisp routine to change properties of all layers in a drawing except one(or a list of layer) ....
and
.... let say I want change color of  all layers  to "6". How it will be now?
To change the color of all Layers to 6 except a single Layer, you can do just this, with a tilde ~ to negate the one Layer name:
(command "_.layer" "_color" 6 "~ABC" "")
But I haven't found a way to omit more than one Layer name in that approach.  Neither "~ABC,DEF" nor "~ABC,~DEF" works.
If you really mean all Layers in the question quoted above, and not all but one or two as in the original request, use an asterisk *:
(command "_.layer" "_color" 6 "*" "")
Kent Cooper, AIA
Message 6 of 8
Kent1Cooper
I want to have that exceptional layer(s) name to be [p]art of my lisp and not by command line input. i.e., all layers except layer "ABC" or "ABC" and "DEF".
Another approach:
(defun C:TEST (/ lay)
  (while (setq lay (cdr (assoc 2 (tblnext "layer" (not lay)))))
    (if (not (wcmatch lay "ABC,DEF"))
      (command "_.layer" "_color" 6 lay "")
In the case of a single Layer name, you can replace
with
    (if (/= lay "ABC")
If such Layer names might have been made without the same upper/lower-case combination, such a Layer "Abc", replace
with
    (if (not (wcmatch (strcase lay) "ABC,DEF"))
Kent Cooper, AIA
Message 7 of 8
Thanks Kent and Henrique for your reply. This is exactly what I want Smiley Happy
Message 8 of 8
alaafarhat
hello
i was following this issue , since i need also to change all the color of the existing layers in Autocad to the same color with exceptions of one or more layers,
yet i have tried to do so with the existence of blocks and dimensions , i didn't get the needed result ,
How can i convert all the layers that i have into the same color with some exceptions
 Any HELP please ,....
thank you
