lisp to change date of text in more sheet
Message 1 of 8
hi
I have more sheet and i need to change the date in my frame and the attribute in the frame one by one and i need to change date in frame i need to solve it in Alisp to change date
Replies (7)
Message 2 of 8
imadHabash
usually in AutoCAD we use frame sheets and some other repeatable data as an Xref attachments so when we need to make modifications we just make it once in the origin CAD file to be automatically modified in all other files that use this origin file as an attachments. OR  you can take an Ctrl+C from your modidfied date and use PASTEORIG command.
Imad Habash
Message 3 of 8
Vinayv4v
You could use the BFIND Lisp to replace all you want in multiple drawings.
Check this:
http://www.lee-mac.com/bfind.html
Cheers,
Vinay Vijayakumaran
Message 4 of 8
Thank you
but I need the lisp to change 150 Drawing in one command because it difficult to open one by one drawing
thanks
Message 5 of 8
thank you but i cant work at this command
Message 6 of 8
Vinayv4v
This is what BFIND toolbar looks like.
You don't need to open these drawings 1 by 1 for using BFIND.
You Can show the location of the directory (folder) in which all your drawings are present.
The changes will be done in all your 150 drawings with a single click. You just need to download the lisp from the link provided.
Cheers,
Vinay Vijayakumaran
Message 7 of 8
Vinayv4v
Did BFIND solve your issue?
Cheers,
Vinay Vijayakumaran
Message 8 of 8
roland.r71
I'm not so sure.
It only works if the date that needs replacing is the same for all drawings (unlikely)
What he needs, i think, is a way to set the date attribute for a title block (frame), no matter what it contains.
Which should be fairly easy, using a lisp to set the attribute & use a script to run it on all (selected) drawings.
