LISP to change constant attributes to normal
ThomasRambach
Advisor Advisor
ThomasRambach
I have this LISP which works well at converting all constant attributes to normal:
(defun c:attsnotconstant (/ b n)
  (vl-load-com)
  (while (setq b (tblnext "block" (not b)))
    (setq n (cdr (assoc 2 b)))
    (vlax-for o	(vla-item (vla-get-blocks
			    (vla-get-activedocument
			      (vlax-get-acad-object)
			  n
      (if (= (vla-get-objectname o) "AcDbAttributeDefinition")
	(vla-put-constant o :vlax-false)
    (command "attsync" "name" n)
(c:attsnotconstant)
I want to edit this so that it only changes the attribute to normal if the attribute tag is a specific value. Any ideas on how to do this? I'm definitely not an expert in LISP so any help would be appreciated.
Shneuph
I think this would do it:
(vl-load-com)
n
(if (= (vla-get-tagstring o) "Detail_Number");<- put tag name of attribute
);if
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
