LISP to bring blocks to Front with draworder
jarredmonday
jarredmonday
I'm looking to bring certain dynamic blocks in my drawing, that are sometime on multiple layers, to the front using draw order.
I am currently using the Select Similar do what I need but it's becoming tiresome. My goal is to apply a lisp to a toolbar for a one mouse click. I'm okay at using macros and getting what I need but I cannot find a starting point to select blocks by their names and bringing them to the front.
Block name examples:
90-13
CE-13
1161B
...to be continued
Thank you for any advice.
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
jarredmonday
With a bit more research I was able to find this and it works. May someone modify it so the selected object to be brought to Front?
(defun c:QQ (/ a blkname found lst obj objs ss i blk name)
(vl-load-com)
(if (and (setq blkname '("90-13" "CE-13" "1161B"));;
(foreach x blkname
(if (member x
(while (setq a (tblnext "BLOCK" (null a)))
(setq lst (cons (strcase (cdr (assoc 2 a))) lst))
lst
(setq found (cons x found))
found
(setq objs (ssadd)
ss (ssget "_x" '((0 . "INSERT")))
(progn
(repeat
(setq i (sslength ss))
(setq blk (ssname ss (setq i (1- i))))
(setq obj (vlax-ename->vla-object blk))
(setq name
(if (vlax-property-available-p obj 'effectivename)
(vla-get-effectivename obj)
(vla-get-name obj)
(if (member (strcase name) blkname)
(ssadd blk objs)
(if objs
(sssetfirst nil objs)
(cond ((not blkname)
(princ "\n Missed name of block ***")
((not found)
(princ "\n Blocks not found in drawing !!!")
(t
(princ "\n couldn't find any block !!! ")
(princ)
hmsilva
If the the blocks are not dynamic, something like this will do the trick
(defun c:demo (/ ss)
   (if (setq ss (ssget "_X" (list '(0 . "INSERT") (cons 2 "90-13,CE-13,1161B")))) ; Block names
      (command "_.draworder" ss "" "_front")
   (princ)
Hope this helps,
Henrique
hmsilva
II recall that code
Change
to
(command "_.draworder" objs "" "_front")
Hope this helps,
Henrique
jarredmonday
Thank you very much they both are working very well. I did read on that thread that this will only work for dynamic blocks. Thanks for the reminder. Luckily I only have one or two regular blocks.
hmsilva
You're welcome, jarredmonday!
No, the code will work for dynamic and regular blocks...
Henrique
88kedzior88
(defun c:fr(/ a)
    (setq a (ssget "_I"))
    (sssetfirst a a)
    (command "_.draworder" "_front")
1) select objects
2) fr
