Lisp to Auto rename layers
Hey guys,
I've been looking for an AutoLISP that renames layers, but does more than one layer at once (e.g. I don't need to run 20 lisps to rename 20 layers).
Currently I have a list of "Features" and every time i digitise one of these I add a suffix (e.g. FENCE02 or FENCE_02 the software unfortunately only exports Polylines with names as layers) and then later export them all into a .DXF file.  When i get them into AutoCAD I select them, explode them, flatten them, join them (fun 3D PL to PL workflows are fun) and then go about changing all the duplicate layer names to a reference name.
Is there any way I can automate this?  My reference layers are:
ROAD
DRIVEWAY
TOP_OF_BANK
TOE_OF_BANK
EARTH_DRAIN_
RETAINING_WALL
ELEC_POLE
BUSH_EXTENTS
TREE_EXTENTS
TRUNKS_
FENCE_
GATE_
SIGN_
BUILDING
STORMWATER_
ABOVE_GROUND_HYDRANT_
ROAD_FURNITURE_
PIT_TELSTRA_
PIT_GAS_
PIT_SEWER_
PIT_WATER_
PIT_IRRIGATION_
PIT_UNCLASSIFIED_
PIT_IRRIGATION
PIT_UNCLASSIFIED
Any help muchly appreciated, i've had a decent look online and most of the LISPS only change one predefine layer, and my complete lack of LISPING skills means I cannot just copy paste the code with the new refs.
Thanks guys,
K
ВeekeeCZ
Have you tried _LAYTRANS command?
Or you can find the lisp HERE or HERE
pbejse
@Anonymous wrote:
Hey guys,
I've been looking for an AutoLISP that renames layers, but does more than one layer at once ......
..... Any help muchly appreciated, i've had a decent look online and most of the LISPS only change one predefine layer, and my complete lack of LISPING skills means I cannot just copy paste the code with the new refs.
Thanks guys,
K
Request such as this requires complete understanding of WHAT IS and WHAT WILL for layer names, what you need is a bare RENAME lisp function that accepts a list of LAYER NAMES as arguments supplied by the user, perhaps from a list on a TEXT (txt) file so users can easily add more names without modifying the lisp program.
It pretty easy K
p
I was initially thinking tha a rename function of some sort would work but wasn't sure what wildcards to use or how to structure it...  That said now that I have that structure in the LISP BeekeeCZ has provided I can probably figure it out.  I hadn't seen a LISP so basic, some of the other one i was looking at used VLISP and LISP and had quite complex bodies so I shied away from them.
I'll give this a stab, thanks.
Also the LayerTrans table will work for me until I have some time to make this puppy up, so thanks BeeKeeCZ. Amazing that I've never come across LayerTrans, that's ridiculously helpful.
Thanks a whole heap guys.
Kudos to this forum and the people in it for making my life a little less monotonous!
