Announcements
LISP to assign the layer for selected object OR assign the layer as active one if no selected object
bigcarl5000kg
bigcarl5000kg
Dear community,
please, can someone create a LISP for assigning a predefined layer to the selected objects, if no objects were selected, then the predefined layer would only be set as active.
Example:
I have objects of different types selected, after calling LISP, the "CONTOUR" layer would be assigned to them, if I had no other object in the active selection, after calling LISP the "COUNTOUR" layer would be set as the currently active one, so that I could create new objects in it.
I don't know if this can be replaced using a command macro, that's why I chose the LISP option.
Thank you in advance for your help
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
paullimapa
give this a try:
; chssly function takes layer name as argument
; if there are objects actively selected will change them to that layer
; else sets layer current
; Example:
; (chssly "CONTOUR") ; will change objects in active selection to layer "CONTOUR"
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-assign-the-layer-for-selected-object-or-assign-the-layer/m-p/11974514#M448598
(defun chssly (lyr / chk_ly cly ss)
 (defun chk_ly (nam)
  (if(not(tblsearch"Layer" nam))(command-s "'_.Layer" "_New" nam "" "")) ; create new layer if not exist
 (if(setq ss(ssget "_I")) ; if there are objects actively selected
  (progn
   (chk_ly lyr)
   (foreach b (mapcar 'cadr (ssnamex ss))  ; create list of all entities from selection set & cycle through
    (if (= 'ename (type b)) ; confirm is entity
     (vla-put-layer (vlax-ename->vla-object b) lyr) ; change object to layer
   ) ; loop
   (princ(strcat"\nSelected Objects Successfully Changed to Layer: [" lyr "]."))
  ) ; progn
  (progn
   (chk_ly lyr)
   (setvar"clayer"lyr) ; set as current layer
   (princ"\nNo Objects are actively selected.")
  ) ; progn
 )(princ)
) ; defun
Paul Li
IT Specialist
@The Office
komondormrex
hi there,
code from adjacent topic, slightly refurbished.
(defun get_layer (/ temp_file_path dcl_filename_full sl_dcl_iddcl_file_id  dwg_layers_list index selected_layer)
  	(setq temp_file_path (vla-get-TempFilePath (vla-get-Files (vla-get-preferences (vlax-get-acad-object))))
		  dcl_filename_full (vl-filename-mktemp "Dialog" temp_file_path ".dcl"])
		  dcl_file_id (open dcl_filename_full "w")
  	(vlax-for dwg_layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
			(setq dwg_layers_list (append dwg_layers_list
									  (list (vla-get-name dwg_layer))
	(setq dwg_layers_list (acad_strlsort dwg_layers_list))
	(mapcar '(lambda (dcl_str) (write-line
									dcl_str
									dcl_file_id
		 	 (list
		 		"Layers_List : dialog {"
    	 								"label = \"Pick layer\";"
		 									": list_box {"
		 													"key = \"Dwg_Layers_List\";"
		 													"width = 50;"
		 													"height = 20;"
		 									"ok_cancel;"
	(close dcl_file_id)
	(setq sl_dcl_id (load_dialog dcl_filename_full))
	(if sl_dcl_id
		(if (new_dialog "Layers_List" sl_dcl_id)
			(progn
			  	(start_list "Dwg_Layers_List" 3)
					(mapcar 'add_list
					  	(mapcar '(lambda (list_element)
					  			 	(strcat "\n" list_element)
					  			 dwg_layers_list
				(end_list)
				(action_tile "Dwg_Layers_List" "(cond
										(= 4 $reason)
											(setq index $value)
											(done_dialog 1)
										t
											(setq index $value)
				(setq dialog_result (start_dialog))
				(unload_dialog sl_dcl_id)
				(vl-file-delete dcl_filename_full)
				(cond
						(= 1 dialog_result)
							(if index
								(setq selected_layer (nth (atoi index) dwg_layers_list))
						t
							(setq selected_layer nil)
	selected_layer
(defun c:move_to_layer (/ enames_sset move_to_layer_name)
	(if (setq move_to_layer_name (get_layer))
		(if (setq enames_sset (ssget))
			(progn
				(if move_to_layer_name
					(foreach object (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex enames_sset))))
						(vla-put-layer object move_to_layer_name)
					(alert "No layer was selected!")
			(vla-put-activelayer (vla-get-activedocument (vlax-get-acad-object))
					     (vla-item (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) move_to_layer_name)
		(alert "\nNo layer was selected")
	(princ)
Kent1Cooper
@bigcarl5000kg wrote:
... a LISP for assigning a predefined layer to the selected objects, if no objects were selected, then the predefined layer would only be set as active. ....
I have had this simple command to do exactly that with Layer "0" for years.  Just substitute your desired Layer name.
(defun C:L0 ()
  ; put pre-selected object(s) [if any] on Layer 0, otherwise set current Layer to 0
  (if (ssget "_I")
    (command "_.chprop" "_layer" "0" ""); then
    (command "_.layer" "_thaw" "0" "_set" "0" ""); else
  ); if
  (princ)
That doesn't allow for the possibility that the Layer may not exist -- not an issue for Layer 0.  Do you need it to make it if it doesn't?  [You did say "predefined."]
Kent Cooper, AIA
bigcarl5000kg
Dear @Kent1Cooper,
your solution is amazing and easy, thank you very much and have a nice day.
WeTanks
Wow! It is great, Thank you very much!
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
