Lisp to add text to all all attributes in a block
neabailey
Message 1 of 8
neabailey
I'm Looking to add an XXX to all attributes in a block. The reason is I have up to 32 empty attributes in a block. I have a way to copy text to attributes for quick redline pick ups but I need a value to pick. So I thought a lisp, lets say its named FILL, would ask to select a block to fill, and I would select and it would insert an XXX in all attributes. Once Im done with the edits, any remaining XXXs I could clear with Lisp I already have that allows me to clear out any attributes that I select.
The blocks are dynamic, but only have attributes in one view.
any ideas?
~nic
Replies (7)
Message 2 of 8
ВeekeeCZ
Possibly like this
(vl-load-com)
(defun c:BAXXX ( / s i o)
  (if (setq s (ssget "_:L" '((0 . "INSERT") (66 . 1))))
    (repeat (setq i (sslength s))
      (foreach o (vlax-invoke (vlax-ename->vla-object (ssname s (setq i (1- i)))) 'getattributes)
	(vla-put-TextString o "XXX"))))
  (princ)
Message 3 of 8
Moshe-A
@neabailey hi,
check this XXXPRO (XXX Propogate) command.
it set's the attribute to xxx only if it's empty \ null string \ not set.
enjoy
Moshe
;;; XXX PROPOGATE
(vl-load-com) ; load activex support
(defun c:xxxpro (/ is_white_space ; local function
		   adoc ss ename AcDbBlkRef AcDbAttrib text)
 ; anonymous function
 (setq is_white_space (lambda (s) (vl-every (function (lambda (n) (member n '(9 32)))) (vl-string->list s))))
 (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
 (vla-startUndoMark adoc)
 (if (setq ss (ssget "_:L" '((0 . "insert") (66 . 1))))
  (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
   (setq AcDbBlkRef (vlax-ename->vla-object ename))
   (foreach AcDbAttrib (vlax-invoke AcDbBlkRef 'GetAttributes)
    (setq text (vla-get-textString AcDbAttrib))
    (if (or (not text) (eq text "") (is_white_space text))
     (vla-put-textString AcDbAttrib "xxx")
    ); if
    (vlax-release-object AcDbAttrib)
   ); foreach
   (vlax-release-object AcDbBlkRef)
  ); foreach
 ); if
 (vla-endUndoMark adoc)
 (vlax-release-object adoc)
 (princ)
); c:xxxpro
Message 4 of 8
neabailey
Thanks! that worked!
Message 5 of 8
neabailey
Thank you! that worked as well, I like that option to not overwrite text that is already there, Thanks again.
Message 6 of 8
neabailey
Would there be a way to reverse this? so if editing is all done, could you make the remaining XXX attributes blank again?
Message 7 of 8
ВeekeeCZ
You might want to try it sometimes... it is not that complicated.
(vl-load-com)
(defun c:BAXXXClear ( / s i o)
	(if (= (vla-get-TextString o) "XXX")
	  (vla-put-TextString o "")))))
  (princ)
Message 8 of 8
Moshe-A
@neabailey ,
here is my fix \ new prompt
Command: XXXPRO
Choose [Show/Clear] <Clear>: s
Select objects: all
5 found
choose 'show' to pop 'xxx'
choose 'clear' to remove 'xxx'
at select object you can select multiple blocks.
enjoy
Moshe
;;; XXX PROPOGATE
(defun c:xxxpro (/ is_white_space _option ; local functions
		   default adoc ss ename AcDbBlkRef AcDbAttrib text)
 (defun _option (def / ask)
  (initget "Show Clear")
  (if (not (setq ask (getkword (strcat "\nChoose [Show/Clear] <" def ">: "))))
   (setq ask def)
   (setq def ask)
 ); _option
 ; here start c:xxxpro
 (if (or (eq (getvar "users1") "")
	 (null (member (getvar "users1") '("Show" "Clear")))
  (setvar "users1" (setq default "Show"))
  (setq default (getvar "users1"))
 (if (and
       (setvar "users1" (setq opn (_option default)))
    (cond
     ((eq opn "Show")
      ); if
     ); case
     ( t
      (if (eq (strcase text) "XXX")
       (vla-put-textString AcDbAttrib "")
     ); case
    ); cond
   ); foreach
  ); foreach
 ); if
 (princ)
); c:xxxpro
