lisp that can be used to delete points on multiple lines
mik501_
Message 1 of 19
mik501_
I'm looking for a lisp that can be used to delete points on multiple lines at the same time
I don't use qucik select because within the actual work, there are scores that have the same color. And I don't want to delete it. I want to delete only the line.
1698392095049.jpg.
Replies (18)
Message 2 of 19
ВeekeeCZ
Post 2 dwgs, states before and after.
Message 3 of 19
mik501_
ok
Message 4 of 19
ВeekeeCZ
So you need to remove lines (only LINEs, not plines or arcs) that have any point on them. Or remove lines that have (at least) 2 points?
Message 5 of 19
mik501_
I mean, I want to delete 2 point on the line. no delete line
Message 6 of 19
ВeekeeCZ
Ohh, sure.
(vl-load-com)
(defun c:RemovePointsOnLine ( / s l n c)
  (if (and (princ "\nSelect points,")
	   (setq s (ssget "_:L" '((0 . "POINT"))))
	   (setq s (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
	   (setq l (ssget '((0 . "LINE"))))
	   (setq l (vl-remove-if 'listp (mapcar 'cadr (ssnamex l))))
	   (setq n 0)
    (foreach p s
      (setq c (cdr (assoc 10 (entget p))))
      (if (vl-some '(lambda (e) (equal c (vlax-curve-getclosestpointto e c) 1e-6)) l)
	(progn
	  (entdel p)
	  (setq n (1+ n))))))
  (princ n) (princ " points removed.")
  (princ)
Message 7 of 19
CADaSchtroumpf
An another one! (copy/paste in command line)
((lambda ( / ss n dxf_ent p1 p2 tmp_ss)
  (cond
    ((setq ss (ssget "_X" '((0 . "LINE") (8 . "0") (67 . 0))))
      (repeat (setq n (sslength ss))
        (setq
          dxf_ent (entget (ssname ss (setq n (1- n))))
          p1 (trans (cdr (assoc 10 dxf_ent)) 0 1)
          p2 (trans (cdr (assoc 11 dxf_ent)) 0 1)
        (command "_.zoom" "_object" (cdar dxf_ent) "")
        (setq tmp_ss (ssget "_F" (list p1 p2) '((0 . "POINT") (8 . "0") (62 . 3) (67 . 0))))
        (if tmp_ss (command "_.erase" tmp_ss ""))
        (command "_.zoom" "_previous")
Message 8 of 19
mik501_
It's great. thank you
Message 9 of 19
mik501_
It's great. And it was so fast it was shocking.
Message 10 of 19
mik501_
sorry for bothering I have another question. Can we create lines from points? Once the line is created, delete that point. A line is created and passes through the center of point.
Message 11 of 19
mik501_
Message 12 of 19
ВeekeeCZ
If you mean some automated process that identifies all 2 points close enough, replaces them with a line, extends ends to some polyline... if so, you need to post a dwg with larger context.
Or just a simple drawing tool with witch the user selects 2 points, it draws a line and extends ends...
Message 13 of 19
mik501_
hi
Message 14 of 19
ВeekeeCZ
Those pairs of points, are always 2 m from each other?
Message 15 of 19
mik501_
yes 2mm alway
Message 16 of 19
ВeekeeCZ
Sorry, no go.
You should start to learn something because that gives you some sort of sense of algorithms. At this point, don't like the amount of assumptions/questions that I would have to make. Good luck, though.
Message 17 of 19
mik501_
very very thank you
Message 18 of 19
pbejse
@mik501_ wrote:
HI THIS DWG.
Am i the only one whos' not seeing the drawing file(s)?
Message 19 of 19
mik501_
i will update
