LISP that autoruns on BOTH drawing creation and '+New Layout' creation
My issue is the setting 'ANNOALLVISIBLE' keeps defaulting to '0' and causing issues.
Not a big deal for a new drawing cause we use a template, but when I click + to create a new layout, it sets the ANNOALLVISIBLE back to '0'. I cannot seems to find a way to get this to set to '1' by default. Hoping a LISP that autoruns upon layout creation was possible
SeeMSixty7
Using an editor reactor you can monitor when the Layout Changes. Then you can check the setting and change if needed. Here is a quick sample. Yo may want to update to only do on certain circumstances, but here you go.
(defun CTABChanged(ReactorObjectID ReactorArgument)
   (if (= (car ReactorArgument) "CLAYOUT")
     (progn
     	(if (= (getvar "ANNOALLVISIBLE") 0)
     	    (progn
     	        (princ "\nSetting ANNOALLVISIBLE to On")
     	        (setvar "ANNOALLVISIBLE" 1)
(defun MyEditorReactor ()
   (if (= CTABEditorReactor nil)
       (setq CTABEditorReactor
           (VLR-Editor-Reactor nil '((:vlr-sysVarChanged . CTABChanged)))
 Good Luck,
Thank you I m not familiar with reactors. Do I just load it like a normal LISP? I cant seem to get this to work, anything special I need to do?
SeeMSixty7
After you load it into AutoCAD you will need to run the MyEditorReactor Function.
If you add it to your ACADDOC.LSP file or some other file that autoloads, then you just need to add a call to the function.
(myEditorReactor)
You can also add it to the code I sent you and save to a file. Included here with the call to the function.
     (progn
     	    (progn
(MyEditorReactor)
Good luck,
Ah, was able to get it to run by adding "c:" before the 'myeditorreactor' function
Added to startup suite and works like a charm, thank you!!!
SeeMSixty7
Glad that worked out for you!
