Lisp Text
Lisp Text
chan230984
Message 1 of 16
Lisp Text
chan230984
Hi All
I have Mtext, I want a lisp that can sort from left to right
Accepted solutions (3)
Replies (15)
Message 2 of 16
hak_vz
Try this.
(defun c:amt (/ ss step i e eo ent ip  mi ma  dx elist minx maxy p1 te );
;Author: hak_vz
;https://forums.autodesk.com/t5/user/viewprofilepage/user-id/5530556
;Created: Tuesday, September 7, 2021
;Posted at: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-text/td-p/10604639
(princ "\nSelect mtext objects to align horizontaly >")
(setq ss (ssget '((0 . "MTEXT"))))
(initget 7)
(setq step (getreal "\nDesired spacing between mtext objects >"))
(setq i -1)
(while (< (setq i (1+ i)) (sslength ss))
	(setq e (ssname ss i))
	(setq eo (vlax-ename->vla-object e))
	(setq ip(cdr(assoc 10(entget e))))
	(vla-getBoundingbox eo 'mi 'ma)
	(setq mi (vlax-safearray->list mi))
	(setq ma (vlax-safearray->list ma))
	(setq dx (car(mapcar '- ma mi)))
	(setq elist (cons (list ip dx e) elist))
(setq minx (apply 'min(mapcar 'caar elist)))
(setq maxy (apply 'max(mapcar 'cadar elist)))
(setq p1 (list minx maxy))
(setq elist (vl-sort elist '(lambda (x y) (< (distance (car x) p1)(distance (car y) p1)))))
(setq i -1)
(while (< (setq i (1+ i)) (length elist))
(setq te (nth i elist))
(setq e (last te) ent (entget e) dx (cadr te))
(setq ent (subst (cons 10 p1) (assoc 10 ent) ent))
(entmod ent)
(setq p1 (mapcar '+ p1 (list dx 0)))
(setq p1 (mapcar '+ p1 (list step 0)))
(princ "\nDone!")
(princ)
(princ "\nCommand AMT aligns multiple MTEXT object horizontally with equal spacing")
(princ)
Miljenko Hatlak
Message 3 of 16
pbejse
@chan230984 wrote:
Hi All
You want the values sorted yes? , Based on the chainage value corretct?
if not then just use TEXTALIGN
Message 4 of 16
chan230984
@pbejse
yes , i want the values sorted , Based on the chainage value
Message 5 of 16
pbejse
@chan230984 wrote:
@pbejse
Lets make it easier and sorted with station number
"PI_001" ->  "PI_002" -> etc
(defun c:SAL (/ ss _NTS pt d i ent MtextColl); sort and align
(defun _NTS (v)
  (vl-list->string
           (Vl-remove-if-not '(lambda (n)(<= 48 n 57))
		(vl-string->list v)
  (if (and
	(setq ss (ssget "_:L" '((0 . "MTEXT")(1 . "*@@_###:*"))))
	(setq pt (getpoint "\nPick new location: "))
	(setq d (getdist pt "\nPick distance between Mtext insertion"))
    (progn
      (repeat (setq i (sslength ss))
	(setq ent (entget (setq e (ssname ss (setq i (1- i))))))
	(setq MtextColl (cons
			  (list (_NTS (read (cdr (assoc 1 ent))))(assoc 10 ent) ent) MtextColl))
        (setq MtextColl (vl-sort MtextColl '(lambda (a b)
			       (< (distof (car a))(distof (car b))))))
      (while (setq a (Car MtextColl))
		(entmod (subst (cons 10 pt) (cadr a) (caddr a)))
	(setq  pt (polar pt 0.0 d)
	       MtextColl (Cdr MtextColl))
  (princ)
HTH
Message 6 of 16
chan230984
@pbejse
; error: bad argument type: stringp PI_001:
Command:
Message 7 of 16
pbejse
Command:
I dont see that error unless you the _NTS sub is not loaded. I sugggest try copying code again.
i Attached the lips on the previous post.
Message 8 of 16
chan230984
@pbejse
Still the same error
Please Let's look at the sample file I attached.
Message 9 of 16
hak_vz
@chan230984
Here is modified version of code that sorts mtext according to station distance. You have to tell that before.
(defun c:amt (/ string_to_list ss step i e eo ent ip  mi ma  dx elist minx maxy p1 te stp txt st )
;Author: hak_vz
(defun string_to_list ( str del / pos )
		(if (setq pos (vl-string-search del str))
			(cons (substr str 1 pos) (string_to_list (substr str (+ pos 1 (strlen del))) del))
			(list str)
(initget 7)
(setq i -1)
	(setq txt (vlax-get eo 'Textstring))
	(setq stp(car(string_to_list txt "\\")))
	(setq stp (substr stp (1-(vl-string-position (ascii "+") stp))))
	(setq stp(string_to_list txt "+"))
	(setq stp (mapcar 'atof stp))
	(setq st (+(* (car stp) 1000.0)(cadr stp)))
	(setq elist (cons (list ip dx st e) elist))
(setq elist (vl-sort elist '(lambda (x y) (< (nth 2 x) (nth 2 y)))))
(setq i -1)
(entmod ent)
(princ "\nDone!")
(princ)
(princ)
Miljenko Hatlak
Message 10 of 16
pbejse
Dont worry about it then 🙂
Message 11 of 16
chan230984
@pbejse
Load Lisp Command: ; error: syntax error
Message 12 of 16
hak_vz
@chan230984Edit my code above. Now it should be OK.
Miljenko Hatlak
Message 13 of 16
pbejse
Why did you marked it as solution if its not working for you @chan230984 ?
Unless i know that it does work for you then you can mark it as a solution.
EDIT: Removed Mark at post # 10
Message 14 of 16
chan230984
@pbejse The code has been fixed. These two lisp's good work just as well.
Thank you
Message 15 of 16
hak_vz
@pbejse  I think OP has accidentally tagged you instead of me. There was an error in my code (empty setq) that caused an error.
Miljenko Hatlak
Message 16 of 16
Sea-Haven
Dont we all hate the 30 minute edit time limit so old fashioned.
