LISP table with hatched areas by layer name
karpki
Message 1 of 37
karpki
Hi experts
I use a lisp to make the table of hatched areas (attached)
It makes it by the area order from biggest to smallest
How to shange lisp so  table will be made by th Layer name but not by Area ? Any ideas ?
The layer name will contain also figure f/e/ 1.aisles 2.services etc etc to build the correct order in table
Replies (36)
Message 21 of 37
hak_vz
(setq e (car (entsel "\nSelect table >")))
(setq eo (vlax-ename->vla-object e))
(if (vlax-property-available-p eo 'entitytransparency T)
	(vlax-put-property eo 'entitytransparency 50)
) ;this works
(if (vlax-property-available-p eo 'CellBackgroundTransparency T)
	(vlax-put-property eo 'CellBackgroundTransparency  2 0 50)
) ;this do not work since ther is no property at least not in 2018
So you have to check if there is a property or method to change table cell background using (vlax-dump-object eo 'T)
Miljenko Hatlak
Message 22 of 37
GasTarRPXJ7
Observer
Observer
Hi all,
HTL6.LSP is very useful. I have a very bad knowledge of Acad and software development. Is there any way to export the LISP table into a predefined excel sheet?
Message 23 of 37
Automohan
Help to modify slightly to work with meter units as attached sample of cross section drawing !
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
Message 24 of 37
hak_vz
@Automohan Adapted to your request
Modify table style "legend" so that text height for is set to 0.6.
(defun c:htl ( / ss layername searchlayers e i eo ss _area arealist doc pt1 area_table)
	(setq ss (ssget '((0 . "hatch"))) searchlayers '("AGGREGATE BASE COURSE" "SUBBASE" "EMBANKMENT") arealist (list))
	(foreach layername searchlayers
		(setq i -1 _area 0.0)
			(while (< (setq i (1+ i)) (sslength ss))
				(setq e (ssname ss i) eo (vlax-ename->vla-object e))
				(cond
					((wcmatch(vla-get-layer  eo) layername)
						(setq _area (+ _area (vla-get-area  eo)))
		(setq arealist (append arealist (list _area)))
	(setq
		doc (vla-get-activedocument (vlax-get-acad-object))
		pt1 (vlax-3d-point (getpoint "\nPick top left table insertion point:  "))
		area_table (vla-addtable (vla-get-modelspace doc) pt1 1 2 1 1)
		area_table (vlax-ename->vla-object (entlast))
	(vla-put-titlesuppressed area_table :vlax-true)
	(vla-put-headersuppressed area_table :vlax-true)
	(setq i -1)
		(while (< (setq i (1+ i)) (length arealist))
		(vla-insertrows area_table i 1.4 1)
		(vla-setcellvalue area_table i 0 (nth i searchlayers))
		(vla-setcellvalue area_table i 1 (rtos (nth i arealist)2 2))
	(vla-setcolumnwidth area_table 0 15)
	(vla-setcolumnwidth area_table 1 5)
	(vla-deleterows area_table (1-(vla-get-rows area_table)) 1)
	(setq i -1 )
    (while (< (setq i (1+ i)) (vla-get-rows area_table))
		(vla-setrowheight area_table i 1.4)
	(princ)
Miljenko Hatlak
Message 25 of 37
Jack535
This is awesome lisp, thank you for posting it! It's exactly what I'm after as well, though for some reason it doesn't work on my smaller hatches, it doesn't give me the layer colours and it creates a huge table? Any idea which bit of the code would solve that please?
Message 26 of 37
hak_vz
@Jack535 I'll check it through next few days.
Miljenko Hatlak
Message 27 of 37
cool.stuff
Good morning,
When I try to use this lisp, I got all areas equal to zero.
Any ideas why?
Message 28 of 37
hak_vz
Any ideas why?
Because hatches should be placed in layers named
Replace according to your need.
Miljenko Hatlak
Message 29 of 37
cool.stuff
Many thanks for your help.
It would be possible to change this lisp please?
Create the same table but according to color and hatch types, and compute total area according to these parameters? For selected hatches?
That would help a lot 🙂
Many many thanks  in advance 🙂
Message 30 of 37
hak_vz
@cool.stuff
Attach sample dwg and provide more details.
Miljenko Hatlak
Message 31 of 37
cool.stuff
Sample DWG.
Message 32 of 37
hak_vz
Try this
(defun c:htl ( / ss color searchcolors e i eo ss _area arealist doc pt1 area_table)
	(setq ss (ssget '((0 . "hatch"))) searchcolors (list) arealist (list) results (list) i -1)
	(setq color (cdr (assoc 62 (entget(ssname ss i)))))
	(if (not (member color searchcolors))(setq searchcolors (cons color searchcolors)))
	(setq acc(strcat "AutoCAD.AcCmColor."  (substr (getvar 'Acadver) 1 2)))
	(foreach color searchcolors
				(cond
					((equal (vla-get-color eo) color)
	(setq i -1)
		(setq results (cons (list (nth i searchcolors)(nth i arealist)) results))
	(setq results (vl-sort results '(lambda (x y)(> (last x)(last y)))))
	(setq searchcolors (mapcar 'car results))
	(setq arealist (mapcar 'cadr results))
	(setq
	(setq i -1)
			(setq clr (vlax-create-object acc))
			(vla-put-colorindex clr (nth i searchcolors))
			(vla-SetCellBackgroundColor Area_table i 0 clr)
	(vla-setcolumnwidth area_table 0 30)
	(vla-setcolumnwidth area_table 1 30)
	(setq i -1 )
		(princ)
Miljenko Hatlak
Message 33 of 37
cool.stuff
Works like a charm!! 🙂
Many thanks 🙂
PS: I cannot mark as answer, just a like.. sorry...
Message 34 of 37
hak_vz
@cool.stuff wrote:
Works like a charm!! 🙂🙂
Next time start new post, paste in code you want to be altered according to your needs and mention me in that post using "@". That way you give solution author chance to receive solution point. I'm glad that code works as you expected.
Miljenko Hatlak
Message 35 of 37
bobflopped
thanks a lot!
Message 36 of 37
Sea-Haven
Worked for me but I would change this line.
(setq lname(substr (setq str2 (car d)) 5 (- (strlen str2) 0)))
(setq lname (car d))
Message 37 of 37
hak_vz
@bobflopped
The code you have has been written according to @karpki  request, so as @Sea-Haven  mentioned above, make changes to line related to layer name
Miljenko Hatlak
