Message 1 of 18
Coworker and I are trying to use lisp for work. When coworker is able to get it to run just fine. When I use appload it says it was successfully loaded but then I try and run the command for it to work and it does not pop up on list of commands when I type in command.
I have looked at other posts and saw that I should drag and drop the lisp file into an open session of autocad and I get "error; syntax error".
Another suggestion I found was to check if lisp encoding. I used notepad++ and saw it was ANSI and under language it was LISP.
Since my coworker got it to work I believe there is some setting that is not right.
Any ideas?
