Lisp: select only blocks in selection, disregard rest
Message 1 of 13
Hi and thanks in advance for taking time to read this.
I'm looking for a lisp so i can filter all non-blocks out of a selection.
Preferably after I've made a selection I'ld like to type this command and only have "blocks" in my selection, so I can 'group' them.
I don't want to use "quick selection" cause I have to use too frequently (and I always have to select all the settings).
Anybody have any ideas?
Replies (12)
Message 2 of 13
rkmcswain
Do you mean you want to make a selection on screen, and have it return only block insertions?
Perhaps something like this?
(setq sset (ssget '((0 . "INSERT"))))
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 13
Correct, First I want to make a selection (blocks with other stuff like lines, circles, text etc).
Then I want to type the command, and have only remaining blocks, so I can group them.
The other way around would also work (first command then selection, then group)
If I load it like this however, I can't group it
(defun C:XCLUDE	(
(princ)
Message 4 of 13
Kent1Cooper
@Anonymous wrote:
.... First I want to make a selection (blocks with other stuff like lines, circles, text etc).
Try this [in simplest terms, minimally tested]:
(defun C:SBO () ; = Selected Blocks Only
  (if (ssget "_I"); there are preselected objects [= Implied selection]
    (sssetfirst nil (ssget "_I" '((0 . "INSERT")))); select/grip/highlight only Blocks among them
[That will also include "INSERT" object types other than just Block references, such as XREF, MINSERT, WMF.]
Kent Cooper, AIA
Message 5 of 13
Thank you so much, this works like a charm.
What line do I have to add so it will also "group" the remaining items?
(command "group")
or
(command "_.group")
doesn't seem to work
Message 6 of 13
patrick.ouellet-fortin
Is there any way to use it and select specifically a block named "TEST" by exemple?
Message 7 of 13
Kent1Cooper
As long as it's not a dynamic Block [which can't be filtered for by Block name].  Just add the entry for Block name:
(sssetfirst nil (ssget "_I" '((0 . "INSERT") (2 . "TEST"))))
Kent Cooper, AIA
Message 8 of 13
Thank you!
Message 9 of 13
diagodose2009
You can old method inside Block/s.  If you develope visual-lisp, then you can send the variable
 (setq a208 (ssget))
  (setq disregard (ssget "X" (cons 0 "INSERT")))
 You call the function (setq selectonlyblocks (dfn_ssg_xor a208 disregard))
You use this function , when you do not need selectall method.
Message 10 of 13
cmacdonald
@Kent1Cooper Question.  Also to preface, I have absolutely no experience with LISP.  Just trying to follow along here.  So apologies in advance if I sound silly!
Do wildcards work where that block name field is?  In other words would (2 . "*CAEX*") work in place of that?
I have block definitions uniquely identified and appended with _CAEX to allow doing QSE and entering attribute information in to instances of said blocks, and then later be extracted into tables.  But, as the OP said each time I need to update attribute information in can be a total time suck redoing all of the settings in Quick Select prompt.
Also, is there really no way to do the same thing with a dynamic block?  Again, I am simply filtering these blocks out for attribute editing purposes.  But they do have visibility states, stretch commands, etc.
TIA
-Chris
Message 11 of 13
Sea-Haven
Q1 (2 . "*CAEX*")  should work
Copy this line to command line
(princ (sslength (ssget "X" (list (cons 0  "INSERT")(cons 2  "*CAEX*")))))
Q2 dynamic blocks yes can get dynamic properties, visibility state name, Distance 1 and so on. Use Lee-mac dynamic block properties lsp.
Depending on how complex it all becomes worst case is you may need to pay for some help, but in mean time explain more, need a sample dwg to match your requests.
Message 12 of 13
Kent1Cooper
Also, is there really no way to do the same thing with a dynamic block?  ....
Yes to the first, no to the second if by "the same thing" you mean by way of (ssget).  It can read only things in the entity data list, and the underlying Block name of a dynamic Block insertion isn't in there.  You would need to find all Blocks [filtered by whatever criteria work for you, such as only those on a particular Layer], and step through the selection, checking the effective name of each, removing those that don't have the right one from the selection.  You can find many examples of how to get the effective name in this Forum or the base AutoCAD Forum.
Kent Cooper, AIA
Message 13 of 13
cmacdonald
Thanks gents!
