LISP : select line in specific layer and change...
RémiL
RémiL
Hi ! Little designer here.
I'm looking to create LISP file to automate some tasks :
How to be able to select all the lines of the layer "Wall" and modify them in color "by layer" ?
Thx in advance for your feedback
Remi L.
Modeleur Revit Structure
Logo_Betrec_petit_format
Moshe-A
Remi,
why create a lisp when AutoCAD gives all the tools you need to do that by your own
look at QSELECT  (or FILTER) commands. after you select all objects in layer "Wall" change their color with properties toolbar or ribbon or properties palette.
cheers
moshe
RémiL
Hi @Moshe-A
Because I have several manipulations of this kind to do on hundreds of files Smiley LOL
Remi L.
Moshe-A
check this:
(defun c:byl (/ ss)
 (if (setq ss (ssget "_x" '((8 . "wall"))))
  (command "_.chprop" "_si" ss "_color" "_bylayer" "")
 (princ)
RémiL
AutoCad say me :
the object is not in the current space
Remi L.
Moshe-A
you need to be in model space
RémiL
Yes i'm there Smiley Frustrated
EDIT : ok it's done !!! Thx a lot
Remi L.
