LISP .scr : Hi LIPS Masters Can we copy data DWG/DXF to other DWG/DXF
puneet_psc
puneet_psc
Dear Masters,
The script/LISP is new for me, so please help me to write a script to copy all data from one DWG/DXF to another DWG/DXF.
Thank you
Replies (7)
handjonathan
Hi @puneet_psc
Thanks a lot for posting your question to the forums!   Take a look at this link from @Lee_Mac
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Sea-Haven
What about insert other dwg into current dwg ?
puneet_psc
👉What about insert other dwg into current dwg ?
@Sea-Haven Yes, It will be useful for me
for more clarification: - I am using software for exporting Isometric Drawings in DXF format but intelligent or colored backing sheet/title block  can't export from that software, so I am planning to export DXF without title block/backing sheet after that will use bath file to insert the title block in all .dxf with the help of LISP
Thank you @Sea-Haven
puneet_psc
Yes, I want to attach the file, Please share some script, It will be a great help for me @Sea-Haven
LISP Master Please help me here to share a script that can help me to attach another dwg
Sea-Haven
When you type insert a option is to look via explorer for another dwg then insert it.
Why not open other dwg then just select what you want Ctrl+c, close dwg, should be back in original dwg, then just Ctrl+V. No code required.
If it is something you want in every project then add the block to your DWT ie template dwg, you can purge out unused blocks.
komondormrex
since the topic is almost similar to the adjacent one, and as far as i understand the input data, also minding not it is apprentice, i am placing this take to test.
(defun check_layer_exist (layer_name odbx_object / )
		(if (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list (vla-get-layers odbx_object) layer_name)))
			(vla-add (vla-get-layers odbx_object) layer_name)
		layer_name
(defun get_filename (extension / output_name filename)
	(setq output_name (strcat (vlax-get (vla-get-activedocument (vlax-get-acad-object)) 'path) "\\A3_"
							  (vl-filename-base (vlax-get (vla-get-activedocument (vlax-get-acad-object)) 'name))
	(if (type acet-ui-getfile)
			(setq filename (acet-ui-getfile (strcat "Enter " (strcase extension) " filename") output_name extension "" 1))
			(setq filename (getfiled "Enter CSV filename" output_name extension 1))
	(if (= "" filename) nil filename)
(defun create_dummy_dwg_file (/ dummy_dwg_filename acad_dbx_object)
	(setq dummy_dwg_filename (strcat (vla-get-tempfilepath (vla-get-files (vla-get-preferences (vlax-get-acad-object)))) "Dummy.dwg"))
	(if (findfile dummy_dwg_filename) (vl-file-delete dummy_dwg_filename))
	(setq acad_dbx_object (vlax-create-object (strcat "objectdbx.axdbdocument." (substr (getvar 'acadver) 1 2))))
	(vl-catch-all-apply 'vla-open (list acad_dbx_object dummy_dwg_filename))
	(vla-saveas acad_dbx_object dummy_dwg_filename)
	(vlax-release-object acad_dbx_object)
	dummy_dwg_filename
(defun c:partial_dwg_A3_export (/ odbx_to_objects_list llc_list ruc_list min_x min_y max_x max_y boundary_rectangle boundary_center
							      selection_center dummy_full_name acad_dbx_object odbx_objects_list screen_size boundary_center
	(if (minusp (vlax-get (vla-get-system (vla-get-preferences (vlax-get-acad-object))) 'singledocumentmode))
			(vla-set-singledocumentmode (vla-get-system (vla-get-preferences (vlax-get-acad-object))) :vlax-false)
	(setq odbx_to_objects_list (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget))))))
	(foreach object odbx_to_objects_list
		(vla-getboundingbox object 'llc 'ruc)
		(setq llc_list (append llc_list (list (vlax-safearray->list llc)))
			  ruc_list (append ruc_list (list (vlax-safearray->list ruc)))
	(setq min_x (apply 'min (mapcar 'car llc_list))
		  min_y (apply 'min (mapcar 'cadr llc_list))
		  max_x (apply 'max (mapcar 'car ruc_list))
		  max_y (apply 'max (mapcar 'cadr ruc_list))
		  boundary_rectangle (vlax-invoke (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
										  'addlightweightpolyline
										  (list min_x min_y min_x max_y max_x max_y max_x min_y min_x min_y)
		  boundary_center (vla-addpoint (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
									    (vlax-3d-point (list (* 0.5 (+ min_x max_x)) (* 0.5 (+ min_y max_y))))
	(vla-put-color boundary_rectangle 1)
	(vla-put-color boundary_center 1)
	(setq selection_center (vlax-get boundary_center 'coordinates))
	(vla-erase boundary_rectangle)
	(vla-erase boundary_center)
	(setq dwg_full_name (get_filename "dwg")
		  dummy_full_name (create_dummy_dwg_file)
	(vla-open acad_dbx_object dummy_full_name)
	(setq graphics_boundary (vla-addlightweightpolyline
								(vla-get-modelspace acad_dbx_object)
				 				(vlax-safearray-fill (vlax-make-safearray vlax-vbdouble '(0 . 11)) (list 5 5 5 589 634.3 589 634.3 113 835 113 835 5))
		  text_boundary (vla-addlightweightpolyline
				 			(vlax-safearray-fill (vlax-make-safearray vlax-vbdouble '(0 . 7)) (list 634.3 113 634.3 589 835 589 835 113))
	(vla-put-closed graphics_boundary :vlax-true)
	(vla-put-closed text_boundary :vlax-true)
	(setq odbx_objects_list
		  (vlax-invoke (vla-get-database (vla-get-activedocument (vlax-get-acad-object)))
		  			  'copyobjects
	(vla-put-layer graphics_boundary (check_layer_exist "AM_2" acad_dbx_object))
	(vla-put-layer text_boundary "AM_2")
	(vlax-map-collection (vla-get-textstyles acad_dbx_object)
		'(lambda (textstyle)
			(if (null (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list (vla-get-textstyles (vla-get-activedocument (vlax-get-acad-object))) (vla-get-name textstyle)))))
					(vla-put-fontfile textstyle (vla-get-fontfile (vla-item (vla-get-textstyles (vla-get-activedocument (vlax-get-acad-object))) (vla-get-name textstyle))))
	(foreach object odbx_objects_list
		(vla-move object (vlax-3d-point selection_center) (vlax-3d-point '(319.65 297)))
	(setq screen_size (getvar 'screensize))
	(vla-put-height (vla-item (vla-get-viewports acad_dbx_object) 0) 594.0)
	(vla-put-width (vla-item (vla-get-viewports acad_dbx_object) 0) (* (car screen_size) (/ 584.0 (cadr screen_size))))
	(vla-put-center (vla-item (vla-get-viewports acad_dbx_object) 0)
					(vlax-safearray-fill (vlax-make-safearray vlax-vbdouble '(0 . 1))
										 (list 420 297)
	(vla-saveas acad_dbx_object dwg_full_name)
	(princ (strcat "\nSelected entities have been written as \"" dwg_full_name "\""))
	(princ)
puneet_psc
Thank you everyone for your kind support,
