Lisp - save info as mtext and not as field
cool.stuff
cool.stuff
Hi!
I've found this lisp online
(defun c:foo (/ p)
(and (setq p (getpoint "\nPick a point: "))
(setq p (entmakex (list '(0 . "TEXT")
'(100 . "AcDbEntity")
'(8 . "text")
'(100 . "AcDbtext")
(cons 10 p)
'(40 . 0.125) ; text height
'(1 . "%<\\AcVar Date \\f \"dd/MM/yyyy HH:mm:ss\">%")
(command "_updatefield" p "")
(princ)
And I have made changes to date and time format.
I dont know lisp programming, nad I would like it to write that date and time format to mtext and not as a field.
Can someone help?
Many thanks
paullimapa
Try this not tested
(defun c:foo (/ p DATE TIME PDATE)
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/write-date-and-time-to-text-file/td-p/1689431
(setq DATE (menucmd "M=$(edtime,$(getvar,date),DDD MON DD YYYY)")
;diesel for date
           TIME (menucmd "M=$(edtime,$(getvar,date), HH:MM:SS AM/PM) ")
;diesel for time
            PDATE (strcat DATE TIME ) ;writes text string
'(8 . "text")
'(100 . "AcDbtext")
(cons 10 p)
(cons 1 PDATE)
(princ)
Paul Li
IT Specialist
@The Office
cool.stuff
Works like a charm!!
Many thanks 🙂
paullimapa
 glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
