lisp run command only on specified filenames
giampaolo.schembri
Message 1 of 8
giampaolo.schembri
hello,
i'm tryng to make a lisp that do a command only if the file name start with specified caracter
but i can't find the right way
any suggestion?
here's my code
(defun c:test1()
	(if ((wcmatch (getvar "DWGNAME") "CH*.dwg" "C1*.dwg" "C2*.dwg" "LI*.dwg" "MN*.dwg" "ON*.dwg" "NO*.DWG" "RJ*.dwg" "SH*.dwg" "WT*.dwg" ))  	;;if file name start with
																																				;; change blcok A / CW
	(command "_-insert" "C:\\dati\\block_update\\blocks\\lin_acquatorre.dwg" "-50,0" "" "" "" "" "" "" "" "" "")								;;insert block
	(entdel (entlast))
	(if (setq ss (ssget "_X" '((2 . "riduzione")))) 																							;block to be replaced
		(repeat (setq n (sslength ss))
		  (setq edata (entget (ssname ss (setq n (1- n)))))
		  (entmod (subst '(2 . "lin_acquatorre") '(2 . "lin_cooling-water") edata))
  • Lisp
Replies (7)
Message 2 of 8
pbejse
@giampaolo.schembri wrote:
hello,
any suggestion?
(defun c:test1 ( / fn ss edata)
  (if
    (and
    	(Setq fn (findfile  "C:\\dati\\block_update\\blocks\\lin_acquatorre.dwg"))
	    (Vl-some '(lambda (nme)
			(if (wcmatch (strcase (getvar "DWGNAME"))
				     (strcat nme "*.DWG"))			;<--  if file name start with
			  nme
		     '("CH" "C1" "C2" "LI" "MN"	"ON" "NO" "RJ" "SH" "WT")
	(progn									;<-- change blcok A / CW
	  (command "_-insert" fn "-50,0" "" "" "" "" "" "" "" "" "")		;<-- insert block
	  (entdel (entlast))
		(if (setq ss (ssget "_X" '((2 . "riduzione"))))			;<-- block to be replaced
HTH
Message 3 of 8
giampaolo.schembri
thanks!
it's fro 2 days that i'm going crazy with that problem
Message 4 of 8
pbejse
thanks!
Glad it works for you. And that is just one of many.
Another way is
(member (strcase (substr (getvar "DWGNAME") 1 2))
HTH
Message 5 of 8
giampaolo.schembri
in this way i have to add my command after the file name definition, right?
command: xxxxx	     )
 1 2 check the first 2 caracters? if i write "1 2 3" i can match 3 caracters
i correctly understand?
Message 6 of 8
pbejse
in this way i have to add my command after the file name definition, right?..
Yes, after the IF statement
	(if
	  		) ;_ end of member
	   (princ "do all this")		;<-- Then
	   (princ "Found no match in filename")	;<-- Else
			) ;_ end of if
.. 1 2 check the first 2 caracters? if i write "1 2 3" i can match 3 caracters
Not quite
--> (substr <String argument> <start postion> <length>)
(substr "Chemical" 1 2) will give "Ch", start at position 1 "C" and give 2 characters "Ch"
If you want 3 characters
(substr "Chemical" 1 3) will give "Ch", start at position 1 "C" and give 3 characters "Che"
Another example
(substr "01234-Chemical" 7 2) will give "Ch", start at position 7 "C" and give 2 characters "Ch"
As test for you:
So if i have "This day is All good" and i want just "All good", what is the correct syntax?
Message 7 of 8
giampaolo.schembri
ok I understand
(substr "This day is All good" 13 14 15 16 17 18 19 20)
in this way check "all good", right?
Message 8 of 8
pbejse
ok I understand
Not quite there yet, did you click on the link my previous post?
-- If length is not specified, the substring continues to the end of str. ---
(substr "This day is All good" 13)
starts at position 13 and gives out the remaining string regardless how long it is.
Good try though. 🙂
Now how do it test for this
"This day is All good" --- > "ALL"
Also keep in mind that the these functions  member | eq | equal  | wmatch | vl-string-search are all case sensitive.
