LISP routine works until I attach to another entity
wicj2015
wicj2015
Hi all:
Please help me see the error of my ways:
This little routine to draw an oft-drawn shape in AutoCAD works as intended unless I select a point on another block, shape, entity when choosing the startpoint. To be clear, when I select the startpoint in space without snapping it to another entity, it draws the pline shape as intended and rotates it to the angle specified, but I really need this to work when attached to something else as that is the end use.
Feel free to criticize my coding structure/methods as I am just starting to learn AutoLISP.
(defun c:BUSH ( / bushstart bushend bushangle startpoint)
(setq bushstart (getdist "\nEnter start size: "))
(setq bushend (getdist "\nEnter end size: "))
(setq bushangle (getangle "\nEnter rotation: "))
(initget 129)
(setq startpoint (getpoint "\npick location of first point: "))
  ; (alert (strcat "Bushing will be "  bushstart  " by "  bushend "\nRotated " bushangle " degrees. \nlocated at " startpoint))
  (setq x_val (car startpoint) )
  (setq y_val (cadr startpoint) )
  (setq y_val1 (+ 0.5 y_val) )
  (setq y_val2 (+ 1 y_val) )
  (setq x_val1 (- x_val (/ bushstart 2)))
  (setq x_val2 (- x_val (/ bushend 2)))
  (setq x_val3 (+ x_val (/ bushstart 2)))
  (setq x_val4 (+ x_val (/ bushend 2)))
  (setq pt2 (list x_val1 y_val))
  (setq pt3 (list x_val1 y_val1))
  (setq pt4 (list x_val2 y_val1))
  (setq pt5 (list x_val2 y_val2))
  (setq pt6 (list x_val4 y_val2))
  (setq pt7 (list x_val4 y_val1))
  (setq pt8 (list x_val3 y_val1))
  (setq pt9 (list x_val3 y_val))
  (setq rotang (* 180.0 (/ bushangle pi)))
  (command "_.layer" "_set" "0" "")
  (command "pline" startpoint "w" "0" "0" pt2 pt3 pt4 pt5 pt6 pt7 pt8 pt9 startpoint "")
  (command "rotate" (entlast) "" startpoint  rotang)
  (setq rotang)
  (princ)
AutoCAD 2024 on Windows 11.
paullimapa
Try turning off your object snap
include at start of your code:
(setq osmode (getvar "osmode")) ; save current setting
(setvar "osmode" 0) ; turn off
then at end of your code restore original setting:
(setvar "osmode" osmode)
Paul Li
IT Specialist
@The Office
wicj2015
Thank you so much paullimapa, that was it and something I don't think I ever would have guessed. I ended up setting the osmode to 0 after the prompts for the angle and startpoint, but setting it before the pline was drawn made all the difference.
paullimapa
Glad to have helped..cheers!!!
Paul Li
IT Specialist
@The Office
