Lisp Routine to Rename and delete autocad layout tabs
emilio24DRY
Message 1 of 10
emilio24DRY
1) Rename Layout Tab
I have a drawing with with "Model" "C-5.1" and "C-5.2" Layout Tabs. I need to rename the "C-5.2" to "C-6.2" in multiple drawings within a custom lisp routine that I already have.
2) Delete Layout Tab
I have a drawing with with "Model" "C-2.1", "C-2.1" and "C-2.3" Layout Tabs. I need to delete "C-2.1" from a drawing that has been "save as" through a lisp routine.
I know that both of these task are simple to do by hand, but I would rather not deal with it manually within our template setup if possible.
Replies (9)
Message 2 of 10
scot-65
I'll let you build on this.
(vla-put-Name (vla-Item (vla-get-Layouts *DOC*) orig) a)
orig= original layout name.
a= new layout name [first check for illegal characters, duplicate names, etc.].
*DOC*= (vla-get-ActiveDocument (vlax-get-acad-object))
2.
(defun c:DLT () (command-s "-Layout" "delete" "")(princ))
Must be in the current layout.
I use this all the time.
Hope this helps.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 3 of 10
paullimapa
Assuming those layout names do exists and there won't be a duplicate when one is renamed then you can run this sequence of commands:
-Layout _Rename C-5.2 C-6.2 -Layout _Delete C-2.1
Then use Lee Mac's Script Writer to automate the process and apply it to all dwgs in a given folder:
Script Writer | Lee Mac Programming (lee-mac.com)
Paul Li
IT Specialist
@The Office
Message 4 of 10
pbejse
There will be two programs? one rename and another to delete layout tabs? on the current drawing session for item 2?
Would you mind sharing the routine here?
Message 5 of 10
jcarter33T87
I would simply use sheetsetmanager (sheetset).  This allows you to rename/renumber sheets as needed and it will update the layout tabs.  You can't delete the layout tabs through this, but they can easily be renamed.
This is just an example.
Message 6 of 10
emilio24DRY
This is perfect. Thanks!
Message 7 of 10
emilio24DRY
The "-layout" command is what I was looking for. I am just adding this command line into the rest of my code. But they are separate commands for different areas of my code.
Message 8 of 10
emilio24DRY
This is another way of doing it-I just didn't want to have to do it manually.
Message 9 of 10
jcarter33T87
Understood. I used it everyday. All my sheets and templates for new projects are set up using sheetset. That way, I do it once in the beginning (using fielded mtext for sheet titles and numbers) then it's simple to rename easily. Fought it for years, finally in 2010 I decided to try it. Worked well, self taught.
Message 10 of 10
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
