Lisp Routine to automatically, rename any block listed in list from old name to new one .
dharunkumar.am
dharunkumar.am
I am new to lisp routines , Is there any way to get a Lisp Routine which can automatically, rename any block listed in list from old name to new one in a single command in.
Kent1Cooper
Something like this [very similar to another current topic]:
(defun C:BNU () ; = Block Name Update
  (foreach item '(("Old1" "New1") ("Old2" "New2") ("OldA" "NewA") ("OldB" "NewB"))
    (if
      (and
        (tblsearch "block" (car item)); block exists in the drawing
        (not (tblsearch "block" (cadr item))); not duplicating an existing name
      (command "_.rename" "_block" (car item) (cadr item)); then
  (princ)
EDIT:  [I just fixed a little something, so if you pulled the code very soon after originally posted, and it didn't work, try it again with the revision.]
A question:  Would it be likely that any of the new Block names is already the name of a Block in the drawing?  If that's possible, should the routine notify the User of any Block name(s) it was unable to change?
Kent Cooper, AIA
dharunkumar.am
Thanks for the reply , can you tell me how to run this lisp after loading into the drawing using Appload.
Kent1Cooper
Just type the command name BNU [always the part immediately following the (defun C:].  You can change that command name to anything you prefer [other than a command name that already exists].
Kent Cooper, AIA
dharunkumar.am
It works perfectly . Thank you so much .
Sea-Haven
If its a I just want it to run when I load, add (C:BNU) as last line in the lisp. I do this for most of my code.
  (princ)
(C:BNU)
