LISP ROUTINE TO ADD BLOCK AT END OF A POLYLINE
Ajohnson0
Message 1 of 30
Ajohnson0
I am need to create a polyline that is the length of 52" and automatically inserts a block at the end of it. Is this possible?
Replies (29)
Message 2 of 30
dlanorh
Yes, but not with the information you've supplied so far.
I am not one of the robots you're looking for
Message 3 of 30
Ajohnson0
What else would you need? new at lisp routines, does my screencast with audio show up?
Message 4 of 30
marko_ribar
Use (getpoint) function to aquire points, then (entmake/x) line/polyline and finally use command INSERT or if you want (vla-insertblock) to insert your BLOCK at the end point of previously created line/polyline... Of course all this through LISP routine...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 5 of 30
Ajohnson0
I do not have experience writing lisp routines, that is the purpose of this post.
Message 6 of 30
dlanorh
I can see the screencast, but it is not legible enough to work out :
Layer for the Line/Polyline and width
Is the angle free (as in the user decides) or is there a certain angle
Block name to insert, and is it always the end point and the same block(s)
Block final layer and is it always the same layer(s)
Message 7 of 30
ВeekeeCZ
A single-straight segment of a polyline?
Message 8 of 30
Ajohnson0
@dlanorh
Layer for the Line/Polyline and width Column_lock/3
Is the angle free (as in the user decides) or is there a certain angle free angle
Block name to insert, and is it always the end point and the same block(s) CL/always at the end/same block
Block final layer and is it always the same layer(s) HARDWARE/yes
Message 9 of 30
dlanorh
OK, maybe an hour as I also have to finish something of my own.
Message 10 of 30
Ajohnson0
@dlanorh appreciate your assistance
Message 11 of 30
ВeekeeCZ
This should be a just a prove of concept... I thought that the last complex expression could be just (getvar 'lastpoint), but that did not work.
See HERE  You need a block with polyline inside. See the block, direction of polyline matters!
(defun c:b48 ( / p)
  (command "_insert" "b48" "_scale" 1 PAUSE PAUSE
	   "_explode" "last"
	   "_insert" "be" "_scale" 1 "_r" 0 (trans (cdr (assoc 10 (reverse (entget (entlast))))) 0 1))
  (princ)
Message 12 of 30
dlanorh
OK Try this
(defun rh:get_pt (msg pt)
  (initget 1)
  (if pt (setq pt (getpoint pt (strcat "\nSelect " msg " Point : "))) (setq pt (getpoint (strcat "\nSelect " msg " Point : "))))
  (reverse (cdr (reverse pt)))
);end_defun
(vl-load-com)
(defun c:LB (/ *error* sv_lst sv_vals c_doc c_spc len s_pt i_pt e_pt l_obj b_obj)
  (defun *error* ( msg )
    (mapcar 'setvar sv_lst sv_vals)
    (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nAn Error : " msg " occurred.")))
    (princ)
  );_end_*error*_defun
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object))
        c_spc (vlax-get-property c_doc (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
        sv_lst (list 'cmdecho 'osmode)
        sv_vals (mapcar 'getvar sv_lst)
  );end_setq
  (mapcar 'setvar sv_lst '(0 0))
(initget 6)
(setq len (cond ( (getreal "\nEnter Line Length <52.0> : ")) (52.0))
(setq s_pt (rh:get_pt "Start" nil) i_pt (rh:get_pt "Direction" s_pt) e_pt (polar s_pt (angle s_pt i_pt) len) l_obj (vlax-invoke c_spc 'addlightweightpolyline (apply 'append (list s_pt e_pt))) e_pt (reverse (cons 0.0 (reverse e_pt))) );end_setq (mapcar '(lambda (x y) (vlax-put l_obj x y)) (list 'layer 'constantwidth) (list "Column_lock" 3)) (setq b_obj (vlax-invoke c_spc 'InsertBlock e_pt "CL" 1 1 1 0));THIS ASSUMES THE BLOCK SCALE IS 1 (x y & z) AND ROTATION IS 0 (vlax-put b_obj 'layer "HARDWARE") (mapcar 'setvar sv_lst sv_vals) (princ) );end_defun
Assumptions, as I didn't ask:
Block Scales are 1 and rotation is 0
Drawing units are in inches
If these are not correct please advise and I will adjust
Ammended code above to allow any length of line (default 52.0)
Message 13 of 30
Ajohnson0
@dlanorh I loaded this and it says rh is an unknown command
Message 14 of 30
Kent1Cooper
Can it be as simple as this?
(defun C:WHATEVER (/ pt1 pt2)
  (command
    "_.pline" (setq pt1 (getpoint "\nStart of Pline: "))
    "_width" 3 3 (setq pt2 (getpoint pt1 "\nDirection: "))
    "_u" ; back off that segment
    "_non" (polar pt1 (angle pt1 pt2) 52) "" ; new end in that direction at required distance
    "_.chprop" "_last" "" "_layer" "Column_lock" ""
    "_.insert" "CL" "@" "" "" ""
    "_.chprop" "_last" "" "_layer" "HARDWARE" ""
[assuming, of course, that the Layers and Block definition already exist in the drawing....]
Kent Cooper, AIA
Message 15 of 30
dlanorh
Sorry, type LB to run it
Message 16 of 30
Ajohnson0
@Kent1Cooper I have a novice question here. Is there a way to make the CL block stay at the end the pline if I need to move it? or better yet erase it as I would have to erase both entities vs erasing just one (if they are grouped or whatever)
Message 17 of 30
Sea-Haven
My $0.05 this is front end then use code already posted. The code can be changed very simply to remember last entry.
Message 18 of 30
dlanorh
Try the attached. Creates an anonymous group of the line and block. type LBG to run
  (initget 1)
);end_defun
(defun rh:make_group ( doc gname lst / c_grps n_grp rtn)
  (setq c_grps (vla-get-groups doc)
        n_grp (vlax-invoke c_grps 'add gname)
  );end_setq
  (vlax-invoke n_grp 'appenditems lst)
);end_defun
(vl-load-com)
(defun c:LBG (/ *error* sv_lst sv_vals c_doc c_spc len s_pt i_pt e_pt l_obj b_obj)
    (princ)
  );end_setq
  (initget 6)
  (setq len (cond ( (getreal "\nEnter Line Length <52.0> : ")) (52.0)))
  );end_setq
  (rh:make_group c_doc "*" (list l_obj b_obj))
  (princ)
);end_defun
Message 19 of 30
Ajohnson0
is there anyway to group the 2 together so that they aren't separate entities?
Message 20 of 30
Kent1Cooper
Put them into a Group or a Block together.  Since they're on different Layers, they can't be a single entity in the strict sense, but a Block containing them can, and a Group containing them can sort of function that way.
Kent Cooper, AIA
