LISP Routine That Writes Filename to Attribute
joelmNKB6B
Message 1 of 15
joelmNKB6B
I have a block that is on every drawing, named “OFIMP_1_0”. I’m looking for a LISP routine that writes the name of the file, minus the extension, to the value for attribute with tag “ole_link” within that block once every time the drawing is opened.
I’ve searched high and low but can’t find a solution to this problem. Some solutions came close, but I was unable to adapt them to meet my specific situation - It seems like it would be pretty straight forward for someone more adept as LISP than me.
So essentially, each time I open the file, the value for attribute tag “ole_link” in the block “OFIMP_1_0” should be equal to the drawing name, minus the .dwg extension.
Replies (14)
Message 2 of 15
ronjonp
Use a field: %<\AcVar Filename \f "%fn2">%
Quick code to populate the blocks:
(defun c:foo (/ s)
  (if (setq s (ssget "_X" '((0 . "INSERT") (2 . "OFIMP_2_0"))))
    (foreach e (mapcar 'cadr (ssnamex s))
      (setpropertyvalue e "OLE_LINK" "%<\\AcVar Filename \\f \"%fn2\">%")
  (princ)
Message 3 of 15
joelmNKB6B
@ronjonp:
I had no idea I would get help so quickly, this is fantastic!
I tried the code and it didn't error out, but nothing happened to the attribute. I don't think that this is related to it not working, but I should have been a little more specific in what I needed - it actually needs to change the value to "C5.06!R1C1:R37C5" (assuming the dwg file is named "C5.06.dwg"). I also should add that I accounted for if it is case-sensitive and made sure everything matched exactly, and made sure the block names matched as well. Here is the edited code made to match the attached picture:
(defun c:foo (/ s)
(if (setq s (ssget "_X" '((0 . "INSERT") (2 . "OFIMP_5_0"))))
(setpropertyvalue e "ole_link" "%<\\AcVar Filename \\f \"%fn2\">%")
(princ)
Thanks again for the quick reply!
Message 4 of 15
ronjonp
@joelmNKB6B Post a sample drawing.
Message 5 of 15
joelmNKB6B
@ronjonp
Here's a sample file, the Block is "OFIMP_2_0".
Thanks!
Message 6 of 15
ronjonp
That's the problem. In your first post the block name is "OFIMP_1_0" but in this drawing it's "OFIMP_2_0"
Change the filter at the top of the code to match the correct blockname: (2 . "OFIMP_2_0")
*Edit:
Try this:
(defun c:foo (/ s)
      (setpropertyvalue e "OLE_LINK" (strcat (vl-filename-base (getvar 'dwgname)) "!R1C1:R37C5"))
  (princ)
Message 7 of 15
joelmNKB6B
Sorry for the slapped-together file - when I originally tested the code, I accounted for the block name and was still unsuccessful. It doesn't seem to be doing anything when I look at the command history. I'm loading the LISP in the CUI/ACAD/LISP files/Filename_To_Attribute.LSP and just assuming it will run when the file is opened. Perhaps it is user error?
Message 8 of 15
ronjonp
@joelmNKB6B
Are you running the code ? 'FOO'
This is what I get from the latest code that was posted.
Also, if these blocks all vary in name by a number the filter can be updated like so to account for 0-99
(2 . "OFIMP_#_0,OFIMP_##_0")
Message 9 of 15
joelmNKB6B
Got it to work upon opening - I renamed the file to "acaddoc.lsp" and removed the first and last lines of code. Now it works perfectly. Thanks, couldn't have done it without you!
(princ)
Message 10 of 15
ronjonp
(princ)
Glad you got it to work :). You can also automatically run the code by simply adding (c:foo) to the end.
Message 11 of 15
joelmNKB6B
@ronjonp
It's mostly been working great, but sometimes the attribute value changes to XXXX upon opening the file, and also it's very odd but the background to the text is opaque. I have tried using multiple blocks, and changing the properties of the text but nothing works. When I edit the attribute manually, the background goes back to clear...any insight to this?
Message 12 of 15
ronjonp
@joelmNKB6B
It looks like you're using the code HERE. That puts a FIELD in the attribute which is denoted by the grey background when FIELDDISPLAY is set to 1 ( it does not plot ). If you see #### try a regen to fix it assuming FIELDEVAL is set correctly.
Message 13 of 15
joelmNKB6B
Setting fieldsdisplay = 0 solved this problem. Since I don't use fields this was the easy way out.
Thanks!
Message 14 of 15
ronjonp
But if you use my code then you are using fields? They are nice because if you change the name of the drawing they will automatically update.
Message 15 of 15
joelmNKB6B
@ronjonp
Wow, fields are amazing! Very powerful and intuitive - I will be using these in the future!
