LISP ROUTINE - Select Blocks by Effective Name and Rotation, Change Custom Dynamic Properties
emreakyazicigsl
Message 1 of 16
emreakyazicigsl
Hey everyone, I'm seeking a LISP that selects blocks according to its name (effective name), its rotation as degrees. Then I want to change their custom dynamic properties (angle, position1x, position1y..) which I want to predefine all.
For example, I want to create a LISP that selects all
BLOCKNAME1 with
50· Rotation, then change
Angle 310 degrees
position1x 10
position1y 15 etc.
Thanks to @ronjonp, he/she created a LISP that selects blocks according to its effective block name, angle, att_tag and att_value which are predefined.
I'm going to attach a dwg and attach the LISP of @ronjonp below. I hope you may help. Thank you.
;; Thanks to @ronjonp
(defun c:foo (/ a o s)
  ;; RJP » 2021-07-20
  (cond	((setq s (ssget "_X" '((0 . "INSERT") (2 . "`*U*,BLOCKNAME1"))))
	 (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	   (or (and ;; Blockname check
		    (= "BLOCKNAME1" (vla-get-effectivename (setq o (vlax-ename->vla-object e))))
		    ;; Get the 'angle1' dyn prop
		    (setq a (vl-some '(lambda (x)
					(if (= (vla-get-propertyname x) "Angle1")
					  x
				     (vlax-invoke o 'getdynamicblockproperties)
		    ;; See of the angle is 'equal' to 50 degrees
		    (equal (angtof "50") (vlax-get a 'value) 1e-8)
		    ;; Check that the attribute with 'tag1' is equal to 'value123'
		    (= "VALUE1111111" (strcase (getpropertyvalue e "TAG1")))
	       (ssdel e s)
	 (sssetfirst nil s)
  (princ)
Replies (15)
Message 2 of 16
ronjonp
BLOCKNAME1 with
Angle 310 degrees
position1x 10
position1y 15 etc.
All you have to do is comment out the attribute check:
;; (= "VALUE1111111" (strcase (getpropertyvalue e "TAG1")))
Then when you have a selection modify the properties you need to change in the properties palette.
Message 3 of 16
emreakyazicigsl
Yes I tried but this LISP selects according to Angle (Dynamic Property), right now I need Rotation. Also I need to add the part of changing those dynamic properties too after the selection phase.
Message 4 of 16
ronjonp
This?
(defun c:foo (/ o s)
  ;; RJP » 2021-07-20
		    (equal 50. (vla-get-rotation o) 1e-8)
	       (ssdel e s)
	 (sssetfirst nil s)
  (princ)
Use the properties palette to make your property changes .. code is not required.
Message 5 of 16
emreakyazicigsl
BLOCKNAME1 with
Angle 310 degrees
position1x 10
position1y 15 etc.
I didn't see this part. I know I can do it over there but I'm going to prepare for almost 1500 blocks with 8 different rotation status, therefore appyling only one time is too much important for me unfortunately.
Message 6 of 16
ronjonp
8 different rotation status and you're making the same change to them all?
Message 7 of 16
emreakyazicigsl
Not really. for example:
If BLOCKNAME1 & Rotation= 0 then
Angle:0
P1X = 0
P1Y = 60
P2X = 0
P2Y = 30
P3X = 0
P3Y = 40
P4X = 0
P4Y = 50
If BLOCKNAME1 & Rotation= 180 then
Angle:180
P1X = 0
P1Y = -60
P2X = 0
P2Y = -50
P3X = 0
P3Y = -40
P4X = 0
P4Y = -30
If BLOCKNAME1 & Rotation= 90 then
Angle:270
P1X = 60
P1Y = -60
P2X = 40
P2Y = 10
P3X = 40
P3Y = 0
P4X = 40
P4Y = -10
etc. There are lots of combination and blocks, therefore creating a LISP, then prepare every combination of (name&rotation) is much more effective then apply one by one in the long run.
Also I did a little change in your code, the angle was in radians I guess.
(defun dtr (a)
(* pi (/ a 180.0))
(setq ang1 (dtr 50.0))
  ;; RJP » 2021-07-20
		    (equal ang1. (vla-get-rotation o) 1e-8)
	       (ssdel e s)
	 (sssetfirst nil s)
  (princ)
Message 8 of 16
emreakyazicigsl
I tried to alter your code like that with LeeMac's LISP but that didn't work 😂
(defun c:foo2 (/ a o s p dynprops)
  ;; RJP » 2021-07-20
(defun dtr (a)
(* pi (/ a 180.0))
(setq ang2 (dtr 88.0)
	       (ssdel e s)
	 (sssetfirst nil s)
  (setq dynprops (list
		   (cons "Angle1" ang2)
		   '("Position1 X" . 10)			; all dyn-values are numbers - without ""
		   '("Position1 Y" . 10)
		   '("Position2 X" . 20)			; all dyn-values are numbers - without ""
		   '("Position2 Y" . 20)
		   '("Position3 X" . 30)			; all dyn-values are numbers - without ""
		   '("Position3 Y" . 30)
		   '("Position4 X" . 40)			; all dyn-values are numbers - without ""
		   '("Position4 Y" . 40)
(LM:setdynprops p dynprops)
  (princ)
;; Set Dynamic Block Properties  -  Lee Mac
;; Modifies values of Dynamic Block properties using a supplied association list.
;; blk - [vla] VLA Dynamic Block Reference object
;; lst - [lst] Association list of (( . ) ... )
;; Returns: nil
(defun LM:setdynprops ( blk lst / itm )
    (setq lst (mapcar '(lambda ( x ) (cons (strcase (car x)) (cdr x))) lst))
    (foreach x (vlax-invoke blk 'getdynamicblockproperties)
        (if (setq itm (assoc (strcase (vla-get-propertyname x)) lst))
            (vla-put-value x (vlax-make-variant (cdr itm) (vlax-variant-type (vla-get-value x)))))))
Message 9 of 16
ronjonp
Angle:0
P1X = 0
P1Y = 60
P2X = 0
P2Y = 30
P3X = 0
P3Y = 40
P4X = 0
P4Y = 50
Angle:180
P1X = 0
P1Y = -60
P2X = 0
P2Y = -50
P3X = 0
P3Y = -40
P4X = 0
P4Y = -30
Angle:270
P1X = 60
P1Y = -60
P2X = 40
P2Y = 10
P3X = 40
P3Y = 0
P4X = 40
P4Y = -10
(defun dtr (a)
(* pi (/ a 180.0))
  ;; RJP » 2021-07-20
	       (ssdel e s)
	 (sssetfirst nil s)
  (princ)
You can also get radians from degrees like so: (angtof "50")
Message 10 of 16
ronjonp
Based on these directions give this code a try .. although the results seem incorrect to me:
Angle:0
P1X = 0
P1Y = 60
P2X = 0
P2Y = 30
P3X = 0
P3Y = 40
P4X = 0
P4Y = 50
Angle:180
P1X = 0
P1Y = -60
P2X = 0
P2Y = -50
P3X = 0
P3Y = -40
P4X = 0
P4Y = -30
Angle:270
P1X = 60
P1Y = -60
P2X = 40
P2Y = 10
P3X = 40
P3Y = 0
P4X = 40
P4Y = -10
(defun c:foo2 (/ lm:setdynprops dtr l o r s)
  ;; RJP » 2021-07-30
  ;; Returns: nil
  (defun lm:setdynprops	(blk lst / itm)
    (setq lst (mapcar '(lambda (x) (cons (strcase (car x)) (cdr x))) lst))
  (defun dtr (a) (* pi (/ a 180.0)))
  (cond
     ;; Dynamic properties of 'BLOCKNAME1'
     (setq l '("Position1 X"	   "Position1 Y"       "Position2 X"	   "Position2 Y"
	       "Position3 X"	   "Position3 Y"       "Position4 X"	   "Position4 Y"
       (if (= "BLOCKNAME1" (strcase (vla-get-effectivename (setq o (vlax-ename->vla-object e)))))
	 (cond ((equal 0 (setq r (vla-get-rotation o)) 1e-8)
		(lm:setdynprops
		  o
		  (mapcar '(lambda (r j) (cons r j))
			  l
			  (list 0 (dtr 60) 0 (dtr 50) 0 (dtr 40) 0 (dtr 30))
	       ((equal (angtof "90") r 1e-8)
		(lm:setdynprops
		  o
			  l
			  (list (dtr 60) (dtr -60) (dtr 40) (dtr 10) (dtr 40) 0 (dtr 40) (dtr -10))
	       ((equal (angtof "180") r 1e-8)
		(lm:setdynprops
		  o
			  l
			  (list 0 (dtr -60) 0 (dtr -50) 0 (dtr -40) 0 (dtr -30))
  (princ)
Message 11 of 16
emreakyazicigsl
Oh god thank you. There was a little error about positions, I fixed it.
(setq l '("Angle1" "Position1 X" "Position1 Y" "Position2 X" "Position2 Y"
(lm:setdynprops
o
l
(list (dtr 90) 0 60 0 30 0 40 0 50)
You saved my day, I'm trully grateful to you. I can't bethank enough.
Message 12 of 16
ronjonp
Glad you we're able to modify the code and get it working. That's the beginning of becoming a programmer! 🍻
Message 13 of 16
emreakyazicigsl
Thank you even thought you look like kidding with me 😂 I'm preparing some basic stuff but these are much higher level than my current ability. You are trully expert on this issue, not regarding my beginner level.
Message 14 of 16
Sea-Haven
Just a question how many rotation angles is it just 0 90 180 & 270 ? Then a simple which one question or is there other angles ? If so if there is some relationship can the other values not be calculated for any angle ?
Message 15 of 16
jochem.beullens
I have a similar problem. I have a lisp can match the rotation property of one block to another.
(defun C:BlkRot (/ ss1 matblk brot cnt blk obj)
(setq ss1 (ssget (list (cons 0 "INSERT"))))
(if ss1
(progn
(setq matblk (car (entsel "\nSelect Block to match: ")))
(setq brot (vlax-get-property
(vlax-ename->vla-object matblk) 'Rotation))
(setq cnt 0)
(while (< cnt (sslength ss1))
(setq blk (ssname ss1 cnt))
(setq obj (vlax-ename->vla-object blk))
(setq obj (vlax-put-property obj 'Rotation brot))
(setq cnt (1+ cnt))
(princ)
I want to adjust this lisp so I can match the custom property Angle1 from one block to another. I have blocks with dynmic parameters. If I use the rotation parameter it is not the rotation that changes but the property Angle1. The problem is that this property is a custom property and not so easy to get and set this value?
Message 16 of 16
Sea-Haven
Did you look at the dynamic block lisp by Lee-mac it has multiple functions so can get properties of a dynamic block such as a custom angle, not the block rotation.
