LISp routine for selecting dynamic blocks
Hey guys, i have this lisp routine (not written by me) that select block by its names where i can put block name in command line, i need tweaking for it to work on dynamic blocks as well.
 (defun C:SELBLKN ( / e ss) ; by name
(setq e (getstring T "\nType block name(s) to select (comma-delimited list or wildcards): "))
(if (> e "") (setq ss (ssget "_X" (list (cons 2 e)(cons 0 "INSERT")))))
(if (zerop (getvar "CMDACTIVE"))
  (progn (sssetfirst ss ss)(princ "Use 'P' for this selection set: ")(princ))
   ss
(princ "\nSELBLKN commands loaded.")(princ)
Regards
Amr Aly
ВeekeeCZ
Here you go... try..
(vl-load-com)
(defun C:SELBLKN ( / e ss objs blk) ; by name
        objs (ssadd))
  (if (setq ss (ssget "_X" '((0 . "INSERT"))))
    (progn
      (repeat (setq i (sslength ss))
        (setq name (strcase (vla-get-effectivename (vlax-ename->vla-object (setq blk (ssname ss (setq i (1- i))))))))
        (if (wcmatch name (strcase e))
          (ssadd blk objs)))
      (progn (sssetfirst nil objs)
      objs)))
Just tried it today and it works great, thanks a lot for the help.
