LISP Routine for creating schedule?
sascari
sascari
Is there a lisp routine out there that tags objects and creates a schedule based on that objects parameters? ie series of arcs and creates a schedule with the following properties: arc length, arc radius, etc. This would be very helpful thanks!
imadHabash
it's built-in .... please try to use EATTEXT command with their 8/8 steps.
Imad Habash
sascari
I've used eattext and dataextraction. Is there a way to tag each object so I know on the screen which one is being referenced? Typically, eattext just gives a general summary of each object but does not provide a way to indicate which individual object is being referenced. Does this make sense?
imadHabash
then you need an out source services (lisp or plug-ins) that it could help you and as you asked in your OP .
Imad Habash
sascari
Yea. For sure. I was just curious if anyone had posted such a routine out there.
pendean
Community Legend
Community Legend
Try searching the LISP and other customization forums here https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
sascari
I have found a temporary solution. Using the hyperlink command I can tag each object with an id (0,1,2, ...etc). I can bring that ID into the schedule with EATTEXT. This way, I know which arc is being referenced. If anyone has a better solution, feel free to share.
