LISP QSELECT THEN BRING TO FRONT
Message 1 of 10
Can someone write me a lisp that would use the quick select command to find all leaders with layer name "E-ANNO-TEXT" then those selected will bring to front. Thanks in advance.
Replies (9)
Message 2 of 10
vinodkl
May be this would help you out:
http://forums.augi.com/showthread.php?42864-lisp-routine-which-will-pick-specific-layers-amp-bring-t...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 10
StephenThomasGrace
Give this a try.
Load
Type LeaderFront or LF to run
-steve
Message 4 of 10
Thanks Steve!
Message 5 of 10
What if I want to bring to front all LINES & ARC  with "E-ANNO-TEXT" layer?
Message 6 of 10
StephenThomasGrace
Then the ssget, which is the selection set filter, gets update to something like this:
(ssget "_X" '((-4 . "<OR")(0 . "LEADER")(0 . "LINE")(0 . "ARC")(-4 . "OR>")(8 . "E-ANNO-TEXT")))
; if entity is a Leader, a line or and arc... and on layer E-ANNO-TEXT
I updated the lisp and named it AnnoFront since it is not just leaders now
so AnnoFront or AF will run it
enjoy
-steve
Message 7 of 10
Jemauk
@StephenThomasGrace
Thanks for posting this Steve! I need it to do just text on some hand drawn contours. So I would need to modify it to be:
(setq Text (ssget "_X" '((0 . "TEXT")(8 . "-PROPOSED CONTOURS"))))
Would this be correct?
Thank you,
Joseph Mauk
C3D19
Message 8 of 10
Kent1Cooper
[I didn't see this back then, but with the thread revived, I'll point out that this can be simplified by using a comma-delimited string of multiple entity type names (and the same is applicable for any text-string values, such as Layer names), without  the OR wrappers around separate entries:]
(ssget "_X" '((0 . "LEADER,LINE,ARC") (8 . "E-ANNO-TEXT")))
Kent Cooper, AIA
Message 9 of 10
Kent1Cooper
@Jemauk wrote:
@StephenThomasGrace
.... I need it to do just text on some hand drawn contours. So I would need to modify it to be:
Would this be correct? ....
Yes.
Kent Cooper, AIA
Message 10 of 10
Jemauk
Thank you @StephenThomasGrace!
