LISP program not working in 2010 but worked in 2006.
Hello, I am not a LISP expert by any means. The attached LISP program runs in AUTO CAD 2006 but not in later versions, we upgraded to 2010. Any input would be greatly appreciated, or if someone would take a look and see if they could identify the problem.
Thank you,
Scott in WI
hmsilva
Thank you,
Scott in WI
Hi Scott,
in a quick read, what I would suggest to start debugging your code is:
The code uses T as a variable, channge all T instaces to T1, or something else (inside 'SHAPE' function), T is a built-in symbol and seting T as a variable you are redefining it.
After that, try your code, and if it does not work as expected, share with us the error message or what did not happen and it was supposed to happen and a sample dwg.
Hope this helps,
Henrique
Kent1Cooper
[Absolutely they should do that, but if that were the main issue, wouldn't they have had problems even in earlier versions?]
Kent Cooper, AIA
hmsilva
I'm not saying that redefining 'T' is the main issue... It's a start...
in a quick read, I have not seen any version related issue...
Henrique
I changed the T to T1 and it didn't make a difference.
This is what is happening when it runs. I can get to the point where I enter notes. I can put anything on this line and I always get,
; error: bad argument type: FILE nil
Command: Command:
Any Ideas, this does work on a different computer running 2006.
hmsilva
Command: Command:
To debug, load your code in VLIDE, in debug menu -> Break On Error
Open the code in VLIDE
load your code
run the code,
when error Ctrl + F9 will display the code line with error...
Hope this helps,
Henrique
marko_ribar
At first glance when looked into error message you posted, try adding this marked red...
(defun FILER (/ fn CMD)
 (COMMAND "REDRAW")
 (setq #fnam (if #fnam #fnam (strcat (getvar "dwgprefix") (getvar "dwgname") ".350")))
 (setq fn (getstring (strcat "\nFile <" #fnam ">: ")))
 (if (/= fn "")(setq #fnam fn))
 (if
  (findfile #fnam)
   (progn
    (initget "A O")
    (setq CMD (getkword "\nFile exists...Append/Overwrite <A>:"))
    (if (= CMD "O") (setq CMDS "w") (setq CMDS "a"))
   (setq CMDS "w")
 (setq #opn (open #fnam CMDS))
 (princ
  (strcat "\n" #fnam " opened for "
                      (if (= CMDS "w")
                        "writing"
                        "appending") " to."))
) ;end filer
But then again, I don't know why it worked fine in previous versions... (A2006)
Marko Ribar, d.i.a. (graduated engineer of architecture)
