Lisp para seleccionar similar bloques y escalar en xyz
n.lagos.pdr
n.lagos.pdr
Buenas noches estimados, espero esten muy bien. Estoy creando un lisp para automatizar una tarea repetitiva de mi trabajo la cual es realizarle un measure a una polilinea para insertar bloques a una distancia especifica. Esto ya lo tengo resuelto, mi lisp selecciona todas las polilineas segun sus capa y color y realiza el measure pero se insertan con una escala distinta a la original del bloque que es 1. se insertan con una escala de 39.370. Deseo lograr que el lisp me seleccione todos los bloques y cambie sus propiedades de escala en xyz en 1
de antemano gracias
Sea-Haven
If inserting an external dwg, the scale 39.37 May be that you have different units in the 2 dwgs I have seen this happen, Check INSUNITS also in both dwg's.
paullimapa
Check out this thread. Just replace code with your block name to automatically select them and change the xyz scale to 1
https://forum.bricsys.com/discussion/38053/change-block-scale
Paul Li
IT Specialist
@The Office
n.lagos.pdr
Thank you very much for taking the time to respond to my query. You are right, the blocks are drawn at different scales. Actually, I approached the routine differently and managed to automate a lot of my work. Thanks again.
n.lagos.pdr
Thank you for addressing my question. The thread you shared was very helpful. I managed to automate my drawings quite a bit.
