LISP or CODE of wall(2D) that automatically deletes the intersected lines
Message 1 of 8
With intersected lines...that means like a feature of WALL CLEANUP in Revit.... i hope with this lisp i dont have to use Mline and Mledit commands again ..........Thanks in advance & Have a nice day
Replies (7)
Message 2 of 8
ennujozlagam
hello, you can try OVERKILL command. thanks
Message 3 of 8
How overkill can delete intersected lines.......isnt it for overlapped objects?
LOVED THE QUOTE THOUGH.... 😉
Message 4 of 8
ennujozlagam
yes, you are right..thanks
Message 5 of 8
dlanorh
i wrote the attached about a decade ago and it probably could do with updating. It was written to speed up drawing window elevation frame details, but should work for any sort of lines. There are three options L T and X depending on how you want the lines to finally look. The attached pdf explains the options and how to pick.
I am not one of the robots you're looking for
Message 6 of 8
dgorsman
Do it manually a couple of times, on different situations.  Keep track of the steps you take.
Review the steps taken, look for common steps.  Look for where you can use if/else branching to handle differences.  Look for parts that can be repeated or looped.
Look for what the user *must* provide, where the user might need to intervene, and where the computer can calculate/decide things better.
Start looking for the LISP equivalent of each step required.  If you don't know how to use that part of LISP, look it up, ask here/theswamp.org/etc.
Test, with both the original data set and some arbitrary examples.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 7 of 8
THANKS SIR FOR YOUR GREAT HELP!! APPRECIATE IT.
Message 8 of 8
THANK YOU SIR FOR YOUR TIP!!
