lisp on all dwg directory
dvir860
Message 1 of 10
dvir860
hi,
I have to run Lisp on folder with 50 DWG files.
I like to know if I can run Lisp go into the current dwg.'s Directory, get all the dwg. files, open them one by one and run the program in each one then close that .dwg and move on to the next one.
Dvir
Replies (9)
Message 2 of 10
hmsilva
@dvir860 wrote:
hi,
Dvir
Hi Dvir,
one way, is using a script file and Autodesk's ScriptPro
Hope this helps,
Henrique
Message 3 of 10
Lee_Mac
You may also wish to try my old Script Writer program.
For your task, simply enter the Script Line as:
_.open *file* (load "YourProgram.lsp" nil) (c:YourLISPCommand) _.qsave _.close
Message 4 of 10
MehtaRajesh
Please find very simple way to run lisp function on many drawing files present in selected folder.
Step 1: Below Function CreateScript is to be run to create script file for all the drawing files present in selected folder.
            Script file will be created in respected selection folder having name of the folder .scr.
(defun c:CreateScript()
(if (setq WORKINGDWGPATHVal (browseForFolder "Select Folder to create Script file" 1 "d:\\"))
(progn
 (setq myfilenamelist (VL-DIRECTORY-FILES WORKINGDWGPATHVal "*.dwg"))
 (setq scrname (last (sparser WORKINGDWGPATHVal "\\")))
 (setq openfile (open (strcat WORKINGDWGPATHVal "\\"scrname ".scr") "w"))
 (write-line "FILEDIA" openfile)
 (write-line "0" openfile)
 (setq myloopcnt 0)
 (repeat (length myfilenamelist)
  (write-line "OPEN" openfile)
  (write-line (strcat "\"" WORKINGDWGPATHVal "\\" (nth myloopcnt myfilenamelist) "\"" ) openfile)
  (write-line "QSAVE" openfile)
  (write-line "CLOSE" openfile)
  (setq myloopcnt (1+ myloopcnt))
 );repeat
 (write-line "1" openfile)
 (close openfile)
);progn
);if
(princ)
);defun
(defun sparser (str delim / ptr lst)
 (while (setq ptr (vl-string-search delim str))
 (setq lst (cons (substr str 1 ptr) lst))
 (setq str (substr str (+ ptr 2)))
 (reverse (cons str lst))
(defun browseForFolder (title options rootFolder / sh folder folderobject result)
 (vl-load-com)
 (setq
  sh
  (vla-getInterfaceObject
   (vlax-get-acad-object)
   "Shell.Application"
 (setq
  folder
  (vlax-invoke-method
   sh
   'BrowseForFolder
   (vla-get-hwnd (vlax-get-acad-object))
   title
   options
   rootFolder
 (vlax-release-object sh)
 (if folder
  (progn
   (setq
    folderobject
    (vlax-get-property folder 'Self)
   (setq
    result
    (vlax-get-property FolderObject 'Path)
   (vlax-release-object folder)
   (vlax-release-object FolderObject)
   result
Step 2: Create AutoLISP fuction which you want run on DWG File, and Save it as RunFunction.lsp
   (defun RunFunction()
   );defun
   (RunFunction)
Step 3: Open AutoCAD and use Appload and add RunFunction.lsp in Startup Suite (Contents) hence lisp file will be automatically loaded.
Step 4: Run the Script file
Rajesh
Message 5 of 10
One little suggestion Lee, if you ever revisit your Scriptwriter lisp, please can we have a box to paste in the folder address (from Windows Explorer) that the script will run on rather than having to browse for it?
Message 6 of 10
Lee_Mac
Thank you for your suggestion sbanister, there are actually many enhancements that I hope to incorporate into my Script Writer program as and when I find the time to develop the program again. The entire program really needs a complete overhaul and I will likely opt to rewrite the entire code.
Nevertheless, I'm pleased to hear that you like the program!
Message 7 of 10
hmsilva
Old, but very useful...
Cheers
Henrique
Message 8 of 10
Lee_Mac
Cheers
Henrique
Thank you Henrique!
Good to see you still active & posting here, I wish I could participate & contribute here more often, but there simply isn't enough time in the day!
Message 9 of 10
hmsilva
Good to see you here!
Henrique
Message 10 of 10
dvir860
Thank you very much for help
