[LISP] - obtaining the Z label
pakula.michalina
pakula.michalina
I kindly ask for help. Programming is not my forte, especially the syntax I will refer to.
I am preparing a simple LISP for use in Autodesk software. Its main tasks are to get the Z value indicated by clicking the point and insert the point and the label with the height value as text.
Target appearance:
My problem is not knowing how to correct this rather trivial code that I am enclosing, to:
1. The text was inserted in the height of 0.3m (no need to define by the user in the program).
2. The position of the text (Position Z) corresponds to the Z value of the indicated point.
Code:
(defun c:lh (/  p x y ptcoord textloc)
(while
    (setq p (getpoint "\nPick Point: "))
    (command "_POINT" p)
    (setq z (rtos (caddr p)))
    (setq ptcoord (strcat z))
    (setq textloc (getpoint "\nPick Label Location: "))
    (command "_TEXT" textloc p "" ptcoord "")
Thanks in advance for any tips! 🙂
ronjonp
Have you thought about using an attributed block and fields for this? Attached is an example.
Kent1Cooper
I would use a point coordinate filter to get the X & Y coordinates of the Text insertion point from the 'textloc' variable, but the Z coordinate from the point.  And I would specify the rotation -- depending on your version, AutoCAD may or may not default to the latest rotation used, which if it does, may not be 0.  Also, unlike in manual Text operation, within a (command) function the supplying of the text content ends the command -- you don't give it the extra Enter "" to do that.  Try this [untested]:
(defun c:lh (/ p z textloc)
  (while
;;;    (setq ptcoord (strcat z))  ;;; not doing anything for you
    (command "_TEXT" ".XY" textloc (caddr p) 0.3 0 z)
That requires that the current Text Style is defined without a fixed height.  You could also define a Style with a fixed height of 0.3, call for that Style in the Text command, and not supply an answer to the height question that won't be asked.  Even with a non-fixed-height Style, I would suggest calling for the Style with that option in the Text command, since you won't usually know what the current Style is.
Kent Cooper, AIA
pakula.michalina
Yes, I tried this solution. This is the option I actually use. However, it is sometimes tiring when you have to place a lot of such height points. I was thinking about the possibility of optimizing my work using LISP, hence my question 🙂
But that is also a good solution!
I can recommend! Thank you very much!
pakula.michalina
Thank you very much for your help!
This is exactly what I was trying to achieve.
It is true, depending on the version of AutoCAD, the inserted text may be rotated, but it is a matter of adjusting it to your needs (e.g. defining the angle value in the code).
ronjonp
So do you need to actually pick these points or do they exist as another type of object already? This might have potential to be automated even more.
