Lisp Move the text to the center of the Closed polyline
mik501_
mik501_
I want moves text to the center of the closing line. multiple text at the same time.
Automohan
Try this link:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/move-the-mtext-to-the-center-of-the-...
In the code
Change this:
 (0 . "MTEXT")
to this:
 (0 . "MTEXT,TEXT")
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
mik501_
 Thanks, I'm stuck on this problem. It works only with mtext, how to make it work with text?
(defun c:foo (/ _l c d r s s2 x)
  ;; RJP » 2020-11-13
  (defun _l (s) (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
  (if (and (setq s (ssget '((0 . "LWPOLYLINE"))))
	   (setq s2 (ssget "_X" '((0 . "*TEXT"))))
	   (setq s (_l s))
	   (setq s2 (mapcar '(lambda (x) (cons (cdr (assoc 10 (entget x))) x)) (_l s2)))
    (foreach e s
      (vla-getboundingbox (vlax-ename->vla-object e) 'c 'd)
      (mapcar 'set '(c d) (mapcar 'vlax-safearray->list (list c d)))
      (if (setq	r
		 (cdr
		   (vl-some '(lambda (x)
			       (if (and (<= (car c) (caar x) (car d)) (<= (cadr c) (cadar x) (cadr d)))
				 x
			    s2
	(entmod (append (entget r) (list (cons 10 (polar c (angle c d) (* 0.5 (distance c d)))))))
  (princ)
Automohan
See my first post above !
Change:
MText,Text in the code
"Save Energy"
