Lisp Modification
Lisp Modification
thomas_huntFMPXR
Lisp Modification
thomas_huntFMPXR
Been trying to aimplement annotaive scale and text height into lisp but with no luck.  and tips for adding the function to this code?
(defun c:ldr (/ lyr annoscale mleaderstyle pt)
  ;; Settings
  (setq lyr "PV-TEXT-NOTE")
  (command "_.annoscale" "_S" "1:30" "1:15" "1:10")
  (command "_.mleaderstyle" "annoleaderstyle")
    ;equipment pad 1
(setq pt (getpoint "\nEQUIPMENTPAD1"))
  (command "mleader" pt pause "EQUIPMENT PAD 1")
;equipment pad 2
(setq pt (getpoint "\nEQUIPMENTPAD2"))
  (command "mleader" pt pause "EQUIPMENT PAD 2")
;(e)structure
(setq pt (getpoint "\nSTRUCTURE"))
  (command "mleader" pt pause "(E) STRUCTURE")
);end defun
paullimapa
There are a number of problems to your code but it's very easy to check what the problems are:
(1) All this does is set this text string "PV-TEXT-NOTE" to a variable called lyr
But lyr is never used anywhere else in the code.
If you want your MLeaders to be created on this layer and assuming this layer already exists then you should at least have a line of code like this which sets the current layer to that text string:
(setvar "CLAYER" "PV-TEXT-NOTE")
or
(setvar "CLAYER" lyr)
(2) what is this line of code supposed to do:
To test, just enter it at the command line and you'll see the results:
Notice the correct entry is CANNOSCALE
And then AutoCAD is expecting a scale as the response like 1:30 but not "_S" which will return *Invalid*
So the following line of code would be use to set the current Cannoscale to 1:30:
(command "_.Cannoscale" "1:30")
(3) The following line of code does NOT set the current Mleader Style to "annoleaderstyle
But instead the MLeaderStyle command actually brings up the Multileader Style Manager:
paullimapa_1-1750211329023.png1
If you want to set the Mleader Style to an existing style called "annoleaderstyle" then do the following:
(setvar "CMLEADERSTYLE" "annoleaderstyle")
To make life easy your Mleaderstyle "annoleaderstyle" should already be set up with all the annotative properties:
Enter the command MLeaderstyle and do the following:
1) Leader Structure>Scale: toggle Annotative on:
2) Content tab>Text options>Text style: the text style selected should have annotative properties. In this example the Text Style Annostyle is set with Annotative enabled:
Now when you execute your getpoint function & then the Mleader command you'll successfully create the Mleader on the proper layer with annotative properties:
Note: You may want to look up the importance of setting ANNOAUTOSCALE to 4:
(setvar "ANNOAUTOSCALE" 4)
Paul Li
IT Specialist
@The Office
