Lisp make a subset
Lisp make a subset
xuantientutungXUK6E
Message 1 of 10
Lisp make a subset
xuantientutungXUK6E
hi guys
i have a list ( 1 2 3 4 5)
how can i make a lisp subset with result is a list ( (  1 2) (1 3 ) ( 1 2 3) ..............................v .............v)
hope you guys give me some suggestions.
thank you
Replies (9)
Message 2 of 10
Sea-Haven
Using the nth function can make list of lists, your pattern does not seem quite correct.  You need to show more to see what sort of result your after. (list (nth x lst)(nth (+ x 1)))
Message 3 of 10
xuantientutungXUK6E
the result is a list of subset.
example
list is ( 1 2 3 4)
result is ( (1 2 ) (1 3) (1 4) (2 3) (2 4) (3 4) (1 2 3 ) ( 1 2 4) ( 2 3 4) (1 2 3 4))
thanks
Message 4 of 10
Sea-Haven
Need a recursive solution for even more than 4 items. if 4 then total new list is 4+3+2+1=10 items maybe.
Its a lambda style answer and not something I am expert at. If have time will have a go.
Message 5 of 10
ВeekeeCZ
HERE is a sub from Lee Mac that you need.
Message 6 of 10
pbejse
@xuantientutungXUK6E wrote:
list is ( 1 2 3 4)
Are you trying to break somebody's PIN number or something? Smiley Happy
is it just so happen that the list is sorted that way?  will it be ever like this '("A" 2 1.5 "A") ? where the order or type has nothing to do with the result?
'cmon guys, crank up that grey matter of yours and start coding 🙂
Message 7 of 10
Kent1Cooper
@pbejse wrote:
is it just so happen that the list is sorted that way?  will it be ever like this '("A" 2 1.5 "A") ? where the order or type has nothing to do with the result? ....
Despite the heading on that linked thread, Lee Mac's (nCr) routine works with repeat  items in the list, and  with different kinds  of items.  So, given your example list:
(setq lst '("A" 2 1.5 "A"))
Then we do:
Command: (setq result (list lst))
  (("A" 2 1.5 "A")) ; initial result list containing original list [last item in final result]
Command: (repeat (setq m (- (length lst) 2)) (setq result (append (nCr lst (1+ m)) result)) (setq m (1- m)))
  0 [what it returns to the Command line at the end, but what it has built is:]
Command: !result
(("A" 2) ("A" 1.5) ("A" "A") (2 1.5) (2 "A") (1.5 "A") ("A" 2 1.5) ("A" 2 "A") ("A" 1.5 "A") (2 1.5 "A") ("A" 2 1.5 "A"))
EDIT:  Or, to put it together:
(defun AllSubSets (lst / nCr m)
;; (nCr) function by Lee Mac on "Combinations without
;;   repetition 3 and 4 element." thread, February 9, 2016
  (defun nCr (l r)
    (cond
      ((< r 2)
        (mapcar 'list l)
      (l
        (append
          (mapcar '(lambda ( x ) (cons (car l) x)) (nCr (cdr l) (1- r)))
          (nCr (cdr l) r)
    (setq result ; not localized
      (append
        (nCr lst (1+ m))
        result
      ); append
    ); setq
    (setq m (1- m))
  ); repeat
  result ; reported to Command line [also remains in variable]
); defun
Usage:
Command: (AllSubSets '("A" 2 1.5 "A"))
Kent Cooper, AIA
Message 8 of 10
ronjonp
Here's another way using mapcar:
(defun allsubsets (l / i ncr)
  ;; https://www.cadtutor.net/forum/topic/59422-combinations-without-repetition-3-and-4-element/?tab=comments#comment-491704
  (defun ncr (l r)
    (cond ((< r 2) (mapcar 'list l))
	  (l (append (mapcar '(lambda (x) (cons (car l) x)) (ncr (cdr l) (1- r))) (ncr (cdr l) r)))
  (setq i 1)
  (apply 'append (mapcar '(lambda (x) (ncr l (setq i (1+ i)))) l))
(allsubsets '("A" 2 1.5 "A"))
;;(("A" 2) ("A" 1.5) ("A" "A") (2 1.5) (2 "A") (1.5 "A") ("A" 2 1.5) ("A" 2 "A") ("A" 1.5 "A") (2 1.5 "A") ("A" 2 1.5 "A"))
Message 9 of 10
dlanorh
Strictly speaking
("A" 2 1.5 "A")
is not a subset as a proper subset of a set A is a subset of A that is not equal to A, and so should also include ("A") (2) & (1.5)
I am not one of the robots you're looking for
Message 10 of 10
ronjonp
@dlanorh wrote:
Strictly speaking
("A" 2 1.5 "A")
Agreed .. just matching the OP's result list 🙂
Here is another variant using more of Lee's code:
(defun allsubsets (l / lm:unique ncr i)
  ;; http://www.lee-mac.com/uniqueduplicate.html#uniquer
  (defun lm:unique (l)
    (if	l (cons (car l) (lm:unique (vl-remove (car l) (cdr l)))))
  (defun ncr (l r)
  (setq i 0)
  (lm:unique (apply 'append (mapcar '(lambda (x) (ncr l (setq i (1+ i)))) l)))
;; (("A") (2) (1.5) ("A" 2) ("A" 1.5) ("A" "A") (2 1.5) (2 "A") (1.5 "A") ("A" 2 1.5) ("A" 2 "A") ("A" 1.5 "A") (2 1.5 "A") ("A" 2 1.5 "A"))
