Lisp Learning syntax error
GeryKnee
Message 1 of 8
GeryKnee
The following runs errorly
(defun c:xx ( / )
(Setq p0 nil)
(if (setq pt (getpoint "\nSpecify point: "))
(Progn ;;true
(setq i1 0)
if( (or (= i1 0) (/= ptHt p0) )
(Progn ;;true
(setq i1 1)
(setq p0 ptHt)
(princ 1)
);;Progn true
(Progn ;;false
(princ 2)
);;Progn false
);;if
);;Progn true
(Progn ;;false
(setq i2 0)
);;Progn false
);;if
(princ)
Running it i get
Command: xx
Specify point: 12; error: no function definition: nil
Command:
maybe is something simple
I think i have a large road to catch lisp knowledge
Gery
Replies (7)
Message 2 of 8
annoisscary
I believe its this line here
This should fix it
(defun c:xx ( / )
(Setq p0 nil)
(Progn ;;true
(setq i1 0)
(if (or (= i1 0) (/= ptHt p0) )
(Progn ;;true
(setq i1 1)
(setq p0 ptHt)
(princ 1)
);;Progn true
(Progn ;;false
(princ 2)
);;Progn false
);;if
);;Progn true
(Progn ;;false
(setq i2 0)
);;Progn false
);;if
(princ)
And again, all I did was correct the typos on the one line to read:
Message 3 of 8
GeryKnee
Sorry
ptHt is Pt
(defun c:x2 ( / )
(Setq p0 nil)
(Progn ;;true
(setq i1 0)
if( (or (= i1 0) (/= pt p0) )
(Progn ;;true
(setq i1 1)
(setq p0 pt)
(princ 1)
);;Progn true
(Progn ;;false
(princ 2)
);;Progn false
);;if
);;Progn true
(Progn ;;false
(setq i2 0)
);;Progn false
);;if
(princ)
Does the same
Message 4 of 8
annoisscary
Again, same typo. its this line,
;Needs to be,
(if(or(= i1 0)(/= pt p0))
Message 5 of 8
calderg1000
Regards @GeryKnee
It's worth the try, soon you will surely be coding better. Nested Ifa can get a bit confusing.
Although it is not very clear what you are trying to do, but I have tried to interpret your code a bit and verify that there are some lines that are not going to be executed. Because your first conditional will always be true, and the result will be equal to 1
(defun c:x2 (/ )
  (Setq p0 nil)
  (if (setq pt (getpoint "\nSpecify point: "));;;here you must enter a condition that evaluates: true false
    (Progn ;;true
           (setq i1 0)
;;;if( (or (= i1 0) (/= pt p0) );;a parenthesis is missing here
           (if (or (= i1 0) (/= pt p0)) ;;This condition will always be true, therefore the other lines will not be evaluated.
             (Progn ;;true
                    (setq i1 1)
                    (setq p0 pt)
                    (princ 1)
             ;;Progn true
;;;-----------------------------will never be evaluated
             (Progn ;;false
                    (princ 2)
             ) ;;Progn false
           );;if
    );;End Progn true
    (Progn ;;false
           (setq i2 0)
    );;Progn false
  );;if
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 6 of 8
GeryKnee
Thank You Sir
I saw that the prpblem was that i started a code προταση without using "( " on start.
That's because i write codes in pascal.
I found an online list compiler :
https://www.tutorialspoint.com/execute_lisp_online.php
but i wasn't able to use it
Maybe i must try again to do it.
Gery
Message 7 of 8
calderg1000
Dear @GeryKnee
To code interactively, you have the visual lisp editor and as of 2021, VSCode
Here you have information
https://knowledge.autodesk.com/es/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ESP/Au...
Carlos Calderon G
Message 8 of 8
Sea-Haven
Notepad++ has a run code from current file, did use it all the time and as I have said before has bracket checking.
I write most code not spaced but i think for you may be worthwhile to make it easier to see where stuff starts and finishes. This is notepad++ note the red brackets doing auto checking. Just put mouse on bracket and opposite end will be shown.
