LISP is not working in AutoCAD 2015
I have been using the following program in AutoCAD 2011 and when I upgraded to AutoCAD 2015 the program is not working. I don't know anything about LISP So I thought this forum will help me. I hope someone could help me with this program.
(defun tableinfo ( ss / n entlist)
(setq n 0)
(repeat (sslength ss)
(setq entlist (entget (ssname ss n)))
(cond ((member (cdr (assoc 0 entlist)) '("LINE" "POLYLINE"))
(getlinepts entlist)(setq linelist (cons (ssname ss n) linelist)))
((member (cdr (assoc 0 entlist)) '("TEXT" "MTEXT"))
(setq textlist (cons (ssname ss n) textlist)))
((member (cdr (assoc 0 entlist)) '("INSERT"))
(setq blocklist (cons (ssname ss n) blocklist)))
(setq n (1+ n))
;-------------------------- Cell Count/Height/Width Determination ----------------------
;;Gathers x and y positions of lines and polylines in separate lists
;;This is used to determine height/width & # of rows/columns
;;Line info must be gathered first in order to determine
;;cell position of any other gathered information
(defun getlinepts (alist / x xpt ypt)
(foreach x alist
(if (member (car x) '(10 15))
(progn
(if (not (VL-cmdf-position (setq xpt (atof (rtos (car (trans (cdr x) 0 1)) 2 2))) lpxlist))
(setq lpxlist (cons xpt lpxlist)))
(if (not (VL-cmdf-position (setq ypt (atof (rtos (cadr (trans (cdr x) 0 1)) 2 2))) lpylist))
(setq lpylist (cons ypt lpylist)))
);defun
;---------------------------- Text Info and Cell Position -----------------------------------------------------
;;Determine cell position by insertionpoint of text objects
;;(Using text center is probably more reliable)
;;Create list of indexed lists containing "Order", "Position", "Content", "Height", "Rotation", "StyleName" and "TrueColor"
;;to be used to fill acad table after creation
;;If row and column is already in list, replace with combined string
(defun gettxtinfo (alist / x VL-cmdfaobj pos rpos cpos expos)
(setq VL-cmdfaobj (VL-cmdfax-ename->VL-cmdfa-object txt)
pos (trans (midp VL-cmdfaobj) 0 1);Midpoint
rpos (1- (VL-cmdf-position (cadr pos)(VL-cmdf-sort (cons (cadr pos) lpylist) '>)));Row Position
cpos (1- (VL-cmdf-position (car pos) (VL-cmdf-sort (cons (car pos) lpxlist) '<))));Column Position
(if (setq expos (VL-cmdf-position (list rpos cpos) (mapcar '(lambda (x)(cdr (assoc "Position" x))) tinfo)));if cell is taken
(setq tinfo
(replace tinfo expos
(replace
(nth expos tinfo)
2
(cons "Content"
(if (> (cadr pos) (cdr (assoc "Order" (nth expos tinfo))));in order according to y position
(strcat (VL-cmdfa-fieldcode VL-cmdfaobj) " " (cdr (assoc "Content" (nth expos tinfo))))
(strcat (cdr (assoc "Content" (nth expos tinfo))) " " (VL-cmdfa-fieldcode VL-cmdfaobj))
(setq tinfo
(cons
(list
(Cons "Order" (cadr pos))
(Cons "Position" (list rpos cpos));Position
(Cons "Content" (VL-cmdfa-fieldcode VL-cmdfaobj));Content
(Cons "Height" (VL-cmdfa-get-height VL-cmdfaobj))
(Cons "Rotation" (VL-cmdfa-get-rotation VL-cmdfaobj))
(Cons "StyleName" (VL-cmdfa-get-StyleName VL-cmdfaobj))
(Cons "TrueColor"
(if
(= (VL-cmdfa-get-colorindex (VL-cmdfa-get-truecolor VL-cmdfaobj)) 256)
(VL-cmdfa-item
(VL-cmdfa-get-layers ActDoc)
(VL-cmdfa-get-layer VL-cmdfaobj)))
tinfo)))
;(VL-cmdfa-delete VL-cmdfaobj)
);defun
;--------------------------- Block Info and Cell Position -------------------------------------------------------
;;Gather block information
;;determine cell position according to insertion point
;;Create an indexed list of lists containing "Position" (row, column), "ObjID",
;;"Attributes" (attribute id, attributetextstring) and "Scale"
(defun getblockinfo (obj / pos rpos cpos bname objid bobj attid)
(if (= (type obj) 'ename)
(setq obj (VL-cmdfax-ename->VL-cmdfa-object obj))
(setq pos (trans (midp obj) 0 1)
cpos (1- (VL-cmdf-position (car pos) (VL-cmdf-sort (cons (car pos) lpxlist) '<)));Column Position
bname (VL-cmdfa-get-name obj);Block Name
bobj (VL-cmdfa-item (VL-cmdfa-get-blocks ActDoc) bname));Block VL-cmdfa Object
(VL-cmdfax-for i bobj ; Foreach item in block
(if (eq (VL-cmdfa-get-objectname i) "AcDbAttributeDefinition");If item is an attribute
(setq attid (append attid (list (VL-cmdfa-get-objectid i))));List Attribute Id
(setq objid (VL-cmdfa-get-objectid bobj));Block Object Id
(setq binfo
(cons
(list
(Cons "Name" bname)
(Cons "ObjID" objid)
(if (= (VL-cmdfa-get-hasattributes obj) :VL-cmdfax-true)
(Cons "Attributes"
(reverse
(mapcar
'(lambda (x y) (cons y (VL-cmdfa-get-textstring x)))
(VL-cmdfax-safearray->list (variant-value (VL-cmdfa-getattributes obj)))
attid
(Cons "Scale" (VL-cmdfa-get-xscalefactor obj))
binfo))
;-------------------------------------------- REPLACE by Charles Alan Butler---------------------------------------------
;;Cab's replace function used in this routine to avoid overwriting cells and to update cell merge lists
(defun replace (lst i itm)
(setq i (1+ i))
(mapcar
'(lambda (x)
(if (zerop (setq i (1- i))) itm x)
lst
;-------------------------Midpoint-----------------
(defun midp (obj / ObjLl ObjUr)
(VL-cmdfa-GetBoundingBox obj 'ObjLl 'ObjUr)
(mapcar
'(lambda (a b) (/ (+ a b) 2.0))
(safearray-value ObjLl)
(safearray-value ObjUr))
;-------------------------Q&D Number Accumulation---------------------------
;Used in this routine for polar distances to determine which cells to merge.
;;Recursive function possible. Ask Gile (recursion master) if desired.
(defun acnumlist (nlist / acnlist)
(repeat (length nlist)
(setq acnlist (cons (apply '+ nlist) acnlist)
nlist (reverse (cdr (reverse nlist))))
acnlist
;; ・Remove_nth ・ (Lee Mac) ;;
;; ~ Removes the nth item in a list. ;;
(defun Remove_nth (i lst / j)
(setq j -1)
(VL-cmdf-remove-if
(function
(lambda (x)
(eq i (setq j (1+ j))))) lst))
;;; private function (fixo)
(defun setcelltext(cells row column value)
(VL-cmdf-catch-all-apply
'VL-cmdfax-put-property
(list cells 'Item row column
(VL-cmdfax-make-variant
(VL-cmdf-princ-to-string value) 8)))
(defun setgridlines(xlapp range);(fixo)
;; select the range:
(VL-cmdfax-invoke-method range 'Select)
;; get excel application selection property:
(setq range (VL-cmdfax-get-property xlapp 'Selection))
;; get selection borders
(setq borders (VL-cmdfax-get-property range 'Borders))
;; iterate through all edges of the selection
(setq cnt 0)
(VL-cmdfax-for a borders
(setq cnt (1+ cnt))
(function
(lambda ()
(progn
(if (< cnt 5)
(progn
(VL-cmdfax-put-property
a
'LineStyle
(VL-cmdfax-make-variant 1 3)); single line style
a
'Weight
(VL-cmdfax-make-variant 2 3)); lines
a
'ColorIndex
(VL-cmdfax-make-variant 1 5))); color black
;; turn off the diagonal lines:
(VL-cmdfax-put-property a 'LineStyle (VL-cmdfax-make-variant -4142 3))
(princ)
(defun conexcelcolumn (/ a b list1);(Q. J. Chen)
(setq a 65)
(setq list1 nil)
(repeat 26
(setq list1 (append
list1
(list (chr a))
(setq a (1+ a))
(setq a 65)
(repeat 26
(setq b 65)
(repeat 26
(setq list1 (append
list1
(list (strcat (chr a) (chr b)))
(setq b (1+ b))
(setq a (1+ a))
list1
;;; apply props
(defun Orient (xlrange)
(mapcar '(lambda (prop value)
(list xlrange
prop
value
(list 'HorizontalAlignment 'VerticalAlignment 'Orientation)
(list -4143 -4108 (cvunit (cdr (assoc "Rotation" x)) "radian" "degree"))
;------------------------------------------- CONVERT OLD TABLE ROUTINE -----------------------------------------------
(defun c:TE (/ ActDoc *error* orerror otcontents textlist colwidths i mlist p0 hmergelist2 vmergelist2
*Space* lpxlist lpylist tinfo cwidths check tstyle spos newstring
tstylelst blocklist rowheights selsets tstylelst2 tstylelst3
kword linelist binfo rheights hmergelist vmergelist ssitem tblobj mb
colorlst colorlst2 th tr ts tc newstyle RowTypes a acapp acsp address adoc atable borders cnt col data_list fname font prop release row
selrange sset txt_list urange value xlapp xlbook xlbooks xlcells xlrange xlsheet xlsheets)
(VL-cmdf-load-com)
(setq oerror *error*)
(defun *error* ( msg )
(princ (strcat "\n<" msg ">\n"))
(mapcar '(lambda (x)(and x (not (VL-cmdfax-object-released-p x))(VL-cmdfax-release-object x))) (list ssitem))
(setq *error* oerror)
(setvar 'nomutt 0)
(VL-cmdfa-EndUndoMark ActDoc)
(princ)
);defun *error*
(setq ActDoc (VL-cmdfa-get-activedocument (VL-cmdfax-get-acad-object))
*Space* (VL-cmdfax-get-property ActDoc (nth (VL-cmdfa-get-ActiveSpace ActDoc)'("PaperSpace" "ModelSpace"))))
(VL-cmdfa-StartUndoMark ActDoc)
(setq otcontents (ssget))
(Command-s "._zoom" "object" otcontents "")
(princ "\nSorting Line Info...")
(tableinfo otcontents)
(setq lpxlist (VL-cmdf-sort lpxlist '<) lpylist (VL-cmdf-sort lpylist '>))
(princ "\nSorting Text Info...")
(mapcar '(lambda (txt)(gettxtinfo (entget txt))(redraw txt 2)) textlist);;using redraw function To avoid interference
(princ "\nSorting Block Info...")
(mapcar '(lambda (blk)(getblockinfo blk)) blocklist)
(setq colwidths (mapcar '(lambda (x)(- (nth (1+ (VL-cmdf-position x lpxlist)) lpxlist) x))(reverse (cdr (reverse lpxlist))))
rowheights (mapcar '(lambda (x)(- x (nth (1+ (VL-cmdf-position x lpylist)) lpylist)))(reverse(cdr (reverse lpylist)))))
(setq p0 (VL-cmdfax-3d-point (trans (list (car lpxlist) (car lpylist) 0.0) 1 0)));;<---Table Placement (Currently using Top Left corner)
(progn
(princ "\nSearching for merged cells...")
(princ)
(setvar 'nomutt 1)
;-----------------------------------Method to determine which cells to merge--------------------------------------------
;Method fails if missed selection is not possible at zoom level.
;To determine which cells to merge, a selection at point is used.
;For each row, a selection is attempted at each vertical line at row's center.
;If no selection is made, the point is at the center or left of horizontally merged cells.
;For each column, a selection is attempted at each horizontal line at column's center.
;If no selection is made, the point is at the center or upper region of vertically merged cells.
;Continuation of merging is determined by a 'consecutive miss'.
;When a 'consecutive miss' is made, max column/row item is replaced by the next column/row.
(setq selsets (VL-cmdfa-get-selectionsets ActDoc))
(VL-cmdf-catch-all-error-p (VL-cmdf-catch-all-apply 'VL-cmdfa-add (list selsets "InxCheckSet")))
(setq ssitem (VL-cmdfa-item selsets "InxCheckSet")
cwidths (acnumlist colwidths)
rheights (acnumlist rowheights));;col widths & row heights accumulated for polar use
(mapcar '(lambda (pt rh)
(VL-cmdf-catch-all-error-p (VL-cmdf-catch-all-apply 'VL-cmdfa-clear (list ssitem)))
(VL-cmdfa-selectatpoint ssitem (VL-cmdfax-3d-point (polar (list (car lpxlist) (+ pt (/ rh 2)) 0.0) 0 x)))
(if (zerop (VL-cmdfa-get-count ssitem))
(if check
(setq hmergelist (replace hmergelist 0 (replace mlist 3 (1+ (VL-cmdf-position x cwidths)))))
(setq hmergelist
(cons
(setq mlist
(list
(1- (VL-cmdf-position pt lpylist))
)) hmergelist)
check T)
);if
(setq check nil mlist nil)
));lambda
cwidths
);mapcar
);lambda
(member (nth 1 lpylist) lpylist)
rowheights
);mapcar
(mapcar '(lambda (pt cw)
(VL-cmdfa-selectatpoint ssitem (VL-cmdfax-3d-point (polar (list (+ pt (/ cw 2)) (car lpylist) 0.0) (* pi 1.5) x)))
(if check
(setq vmergelist (replace vmergelist 0 (replace mlist 2 (1+ (VL-cmdf-position x rheights)))))
(setq vmergelist
(cons
(setq mlist
(list
(VL-cmdf-position pt lpxlist)
)) vmergelist)
check T)
);if
));lambda
rheights
);mapcar
);lambda
lpxlist
colwidths
);mapcar
(setvar 'nomutt 0)
);progn
(setq hmergelist2 (mapcar '(lambda (b)(list (car b)(cadr b))) hmergelist))
(setq vmergelist2 (mapcar '(lambda (b)(list (car b)(cadr b))) vmergelist))
(mapcar
'(lambda (a / expos)
(if
(setq expos (VL-cmdf-position (list (car a)(cadr a)) vmergelist2))
(setq dmergelist (cons (list (car a)(cadr a)(caddr (nth expos vmergelist))(cadddr a)) dmergelist))))
hmergelist
(setq xlapp (VL-cmdfax-get-or-create-object "Excel.Application");(fixo)
xlbooks (VL-cmdfax-get-property xlapp 'Workbooks)
xlbook (VL-cmdfax-invoke-method xlbooks 'Add)
xlsheets (VL-cmdfax-get-property xlbook 'Sheets)
xlsheet (VL-cmdfax-get-property xlsheets 'Item 1)
xlcells (VL-cmdfax-get-property xlsheet 'Cells)
(VL-cmdfa-put-visible xlapp :VL-cmdfax-true)
(VL-cmdfax-invoke-method xlsheet "Activate")
(setq ecol (conexcelcolumn))
;place text
(mapcar '(lambda (x / r c xlrange)
(setq r (1+ (cadr (assoc "Position" x))) c (1+ (caddr (assoc "Position" x))))
(setcelltext xlcells r c (cdr (assoc "Content" x)))
(setq xlRange (VL-cmdfax-get-property xlsheet "Range" (strcat (nth (1- c) ecol) (itoa r))))
(VL-cmdfax-invoke-method xlRange "Select")
(setq xlRange (VL-cmdfax-get-property xlapp "Selection"))
(Orient xlrange)
tinfo
;place block info
(mapcar '(lambda (x / r c bstring)
(setq bstring "")
(if (cdr (assoc "Attributes" x))
(progn
(mapcar
'(lambda (y )
(setq bstring (strcat ":"(cdr y) bstring)))
(cdr (assoc "Attributes" x)))
(setcelltext xlcells r c (strcat "Block:"(cdr (assoc "Name" x)) bstring))
));if
binfo
;merge cells
(princ "\nProcessing Merge Info")
(defun convertlist ( mrglist / newmrglist)
(foreach x mrglist
(setq newmrglist (append newmrglist (list (strcat (nth (cadr x) ecol)(itoa (1+ (car x)))":" (nth (cadddr x) ecol)(itoa (1+ (caddr x)))))))
(defun applylist ( mrglist / xlRange)
(foreach x mrglist
(setq xlRange (VL-cmdfax-get-property xlsheet "Range" x))
(VL-cmdfax-put-property xlRange "MergeCells" :VL-cmdfax-true)
(setq hmergelist2 (convertlist hmergelist)
vmergelist2 (convertlist vmergelist))
(applylist hmergelist2)
(applylist vmergelist2)
(VL-cmdfax-get-property xlsheet 'Columns)
'AutoFit)
;;; align all columns to center
(setq urange(VL-cmdfax-get-property xlsheet 'UsedRange))
'HorizontalAlignment -4108)
;;; draw grid lines
(setgridlines xlapp urange)
(mapcar '(lambda (x);(fixo)
'(lambda ()
(list xlcells xlsheet xlsheets xlbook xlbooks xlapp)
(setq xlapp nil)
(gc)(gc)(gc)
(ma
Ajilal.Vijayan
Hi Dinesh_55,
Welcome to Autodesk Community.
The code which you posted looks not complete.
Can you try to attach the file (you may need to zip the file or change the extension to *.txt) here ?
I can't upload files, so kindly find the code below
;-------------------------------------- GATHERING TABLE INFORMATION ------------------------------------
(setq n 0)
(setq n (1+ n))
(foreach x alist
(if (member (car x) '(10 11))
(progn
(if (not (vl-position (setq xpt (atof (rtos (car (trans (cdr x) 0 1)) 2 2))) lpxlist))
(if (not (vl-position (setq ypt (atof (rtos (cadr (trans (cdr x) 0 1)) 2 2))) lpylist))
);defun
(defun gettxtinfo (alist / x vlaobj pos rpos cpos expos)
(setq vlaobj (vlax-ename->vla-object txt)
pos (trans (midp vlaobj) 0 1);Midpoint
rpos (1- (vl-position (cadr pos)(vl-sort (cons (cadr pos) lpylist) '>)));Row Position
cpos (1- (vl-position (car pos) (vl-sort (cons (car pos) lpxlist) '<))));Column Position
(if (setq expos (vl-position (list rpos cpos) (mapcar '(lambda (x)(cdr (assoc "Position" x))) tinfo)));if cell is taken
(setq tinfo
(replace
(nth expos tinfo)
2
(cons "Content"
(strcat (vla-fieldcode vlaobj) " " (cdr (assoc "Content" (nth expos tinfo))))
(strcat (cdr (assoc "Content" (nth expos tinfo))) " " (vla-fieldcode vlaobj))
(setq tinfo
(cons
(list
(Cons "Content" (vla-fieldcode vlaobj));Content
(Cons "Height" (vla-get-height vlaobj))
(Cons "Rotation" (vla-get-rotation vlaobj))
(Cons "StyleName" (vla-get-StyleName vlaobj))
(Cons "TrueColor"
(if
(= (vla-get-colorindex (vla-get-truecolor vlaobj)) 256)
(vla-get-truecolor
(vla-item
(vla-get-layers ActDoc)
(vla-get-layer vlaobj)))
tinfo)))
;(vla-delete vlaobj)
);defun
(setq obj (vlax-ename->vla-object obj))
cpos (1- (vl-position (car pos) (vl-sort (cons (car pos) lpxlist) '<)));Column Position
bname (vla-get-name obj);Block Name
bobj (vla-item (vla-get-blocks ActDoc) bname));Block Vla Object
(vlax-for i bobj ; Foreach item in block
(if (eq (vla-get-objectname i) "AcDbAttributeDefinition");If item is an attribute
(setq attid (append attid (list (vla-get-objectid i))));List Attribute Id
(setq objid (vla-get-objectid bobj));Block Object Id
(setq binfo
(cons
(list
(Cons "Name" bname)
(if (= (vla-get-hasattributes obj) :vlax-true)
(Cons "Attributes"
(reverse
(mapcar
'(lambda (x y) (cons y (vla-get-textstring x)))
(vlax-safearray->list (variant-value (vla-getattributes obj)))
attid
(Cons "Scale" (vla-get-xscalefactor obj))
binfo))
(setq i (1+ i))
(mapcar
'(lambda (x)
lst
(vla-GetBoundingBox obj 'ObjLl 'ObjUr)
(mapcar
acnlist
(setq j -1)
(vl-remove-if
(function
(lambda (x)
(vl-catch-all-apply
'vlax-put-property
(vlax-make-variant
(vl-princ-to-string value) 8)))
(vlax-invoke-method range 'Select)
(setq range (vlax-get-property xlapp 'Selection))
(setq borders (vlax-get-property range 'Borders))
(setq cnt 0)
(vlax-for a borders
(setq cnt (1+ cnt))
(vl-catch-all-apply
(function
(lambda ()
(progn
(if (< cnt 5)
(progn
(vlax-put-property
a
'LineStyle
(vlax-make-variant 1 3)); single line style
(vlax-put-property
a
'Weight
(vlax-make-variant 2 3)); lines
(vlax-put-property
a
'ColorIndex
(vlax-make-variant 1 5))); color black
(vlax-put-property a 'LineStyle (vlax-make-variant -4142 3))
(princ)
(setq a 65)
(setq list1 nil)
(repeat 26
(setq list1 (append
list1
(list (chr a))
(setq a (1+ a))
(setq a 65)
(repeat 26
(setq b 65)
(repeat 26
(setq list1 (append
list1
(setq b (1+ b))
(setq a (1+ a))
list1
;;; apply props
(vl-catch-all-apply
'vlax-put-property
(list xlrange
prop
value
(vl-load-com)
(mapcar '(lambda (x)(and x (not (vlax-object-released-p x))(vlax-release-object x))) (list ssitem))
(setvar 'nomutt 0)
(vla-EndUndoMark ActDoc)
(princ)
);defun *error*
(setq ActDoc (vla-get-activedocument (vlax-get-acad-object))
*Space* (vlax-get-property ActDoc (nth (vla-get-ActiveSpace ActDoc)'("PaperSpace" "ModelSpace"))))
(vla-StartUndoMark ActDoc)
(command "._zoom" "object" otcontents "")
(setq lpxlist (vl-sort lpxlist '<) lpylist (vl-sort lpylist '>))
(setq colwidths (mapcar '(lambda (x)(- (nth (1+ (vl-position x lpxlist)) lpxlist) x))(reverse (cdr (reverse lpxlist))))
rowheights (mapcar '(lambda (x)(- x (nth (1+ (vl-position x lpylist)) lpylist)))(reverse(cdr (reverse lpylist)))))
(setq p0 (vlax-3d-point (trans (list (car lpxlist) (car lpylist) 0.0) 1 0)));;<---Table Placement (Currently using Top Left corner)
(progn
(princ)
(setvar 'nomutt 1)
(setq selsets (vla-get-selectionsets ActDoc))
(vl-catch-all-error-p (vl-catch-all-apply 'vla-add (list selsets "InxCheckSet")))
(setq ssitem (vla-item selsets "InxCheckSet")
(vl-catch-all-error-p (vl-catch-all-apply 'vla-clear (list ssitem)))
(vla-selectatpoint ssitem (vlax-3d-point (polar (list (car lpxlist) (+ pt (/ rh 2)) 0.0) 0 x)))
(if (zerop (vla-get-count ssitem))
(if check
(setq hmergelist (replace hmergelist 0 (replace mlist 3 (1+ (vl-position x cwidths)))))
(setq hmergelist
(cons
(setq mlist
(list
(1- (vl-position pt lpylist))
)) hmergelist)
check T)
);if
));lambda
cwidths
);mapcar
);lambda
rowheights
);mapcar
(vla-selectatpoint ssitem (vlax-3d-point (polar (list (+ pt (/ cw 2)) (car lpylist) 0.0) (* pi 1.5) x)))
(if check
(setq vmergelist (replace vmergelist 0 (replace mlist 2 (1+ (vl-position x rheights)))))
(setq vmergelist
(cons
(setq mlist
(list
(vl-position pt lpxlist)
)) vmergelist)
check T)
);if
));lambda
rheights
);mapcar
);lambda
lpxlist
colwidths
);mapcar
(setvar 'nomutt 0)
);progn
(mapcar
(if
(setq expos (vl-position (list (car a)(cadr a)) vmergelist2))
hmergelist
(setq xlapp (vlax-get-or-create-object "Excel.Application");(fixo)
xlbooks (vlax-get-property xlapp 'Workbooks)
xlbook (vlax-invoke-method xlbooks 'Add)
xlsheets (vlax-get-property xlbook 'Sheets)
xlsheet (vlax-get-property xlsheets 'Item 1)
xlcells (vlax-get-property xlsheet 'Cells)
(vla-put-visible xlapp :vlax-true)
(vlax-invoke-method xlsheet "Activate")
;place text
(setq xlRange (vlax-get-property xlsheet "Range" (strcat (nth (1- c) ecol) (itoa r))))
(vlax-invoke-method xlRange "Select")
(setq xlRange (vlax-get-property xlapp "Selection"))
(Orient xlrange)
tinfo
;place block info
(setq bstring "")
(progn
(mapcar
'(lambda (y )
));if
binfo
;merge cells
(foreach x mrglist
(foreach x mrglist
(setq xlRange (vlax-get-property xlsheet "Range" x))
(vlax-put-property xlRange "MergeCells" :vlax-true)
(vlax-invoke-method
(vlax-get-property xlsheet 'Columns)
'AutoFit)
(vlax-put-property
(setq urange(vlax-get-property xlsheet 'UsedRange))
;;; draw grid lines
(vl-catch-all-apply
'(lambda ()
(setq xlapp nil)
(gc)(gc)(gc)
(mapcar '(lambda (txt)(redraw txt 1)) textlist);;using redraw function again
(princ)
(princ)
);defun
Hi vijayan,
Its working now. Because of express tool problem it was not working.Thanks a lot for your support.
