LISP: Increase consecutive number
BriamR
Message 1 of 15
BriamR
Hi! I have this lisp that increments consecutive numbers in blocks with OD in a specific field (INTERNO_SENAL), what I am looking for with your help is that the number with which it begins to enumerate can be entered and not start from 1, also if it is possible that in the OD in the TIPO_SENAL field enter the block name, I attach an example file,
*Note: the attached lisp only works if the data type of the INTERNAL_SENAL field of the OD is in character, if it could work with an integer data type it would be great.
Thanks community.
Replies (14)
Message 2 of 15
Kent1Cooper
@BriamR wrote:
... the number with which it begins to enumerate can be entered and not start from 1....
For that part, one way would be to replace this much:
(setq inc 0)
(repeat len
(setq enam (ssname ss inc))
(setq INTERNO_SENAL (strcat (itao (+ 1 inc))))
with this:
(setq inc 0 num (getint "\nStarting number: "))
(repeat len
(setq INTERNO_SENAL (itao num)))
and replacing this line:
(setq inc (+ 1 inc))
with this:
(setq inc (+ 1 inc) num (1+ num))
Kent Cooper, AIA
Message 3 of 15
Sea-Haven
Kent has provided excellent advice, when I do say block increment I check the blocks 1st and get the highest number so a choice can be made, its hard to remember what was last number across multiple projects.
Starting number:  <12>
Is itao correct ? ITOA
Message 4 of 15
BriamR
Thanks for the help @Kent1Cooper , I followed your instructions but it gives me an error
Starting number: 12
; error: no function definition: ITAO
This line should be like this according to the suggestion of @Sea-Haven, thanks
(setq INTERNO_SENAL (itoa num)))
the drawback is that now numbers are not assigned consecutively to all the blocks, but to just one
Message 5 of 15
ВeekeeCZ
As it seems, (itoa) is not even necessary, it will accept an integer.
Tip: When selection, you can type F for Fence selection that honers the order.
(defun c:addid ( / s n e)
  (or *ad-t* (setq *ad-t* ""))
  (or *ad-i* (setq *ad-i* 1))
  (if (and (not (initget 128))
	   (setq *ad-t* (cond ((getkword (strcat "\nIntroducir nombre de la tabla <" *ad-t* ">: ")))
			      (*ad-t*)))
	   (setq *ad-i* (1- (cond ((getint (strcat "\nIniciar Interno <" (itoa *ad-i*) ">: ")))
				  (*ad-i*))))
	   (princ "\nSeleccionar señales verticales, ")
	   (setq s (ssget))
	   (setq n -1)
    (repeat (sslength s)
      (setq e (ssname s (setq n (1+ n))))
      (ade_odaddrecord e *ad-t*)
      (ade_odsetfield e *ad-t* "INTERNO_SENAL" 0 (setq *ad-i* (1+ *ad-i*)))
      (command "_.chprop" e "" "_c" 1 "")))
  (princ)
(alert "Se actualizaron los bloques seleccionados con INTERNO_SENAL")
(princ)
Message 6 of 15
calderg1000
Regards @BriamR
I made some edits to the reached code and added the Start value request
(defun c:addid1 (/ n inc enam idd)
  (setq tn "SDM_SEN_SENALIZACION")                ;nombre de la tabla fijo.
  (prompt "Seleccionar señales")
  (princ)
  (setq n  (getint "\n Ingrese valor de Inicio: ")
        ss (ssget '((0 . "insert")))
  (setq inc 0)
  (repeat (setq len (sslength ss))
    (setq idd (itoa n))
    (ade_odaddrecord enam tn)
    (ade_odsetfield enam tn "INTERNO_SENAL" 0 idd)
    (command "chprop" enam "" "c" "red" "")       ;.... talvez no sea necesario...???
    (setq inc (1+ inc)
          n   (1+ n)
  (alert "Se actualizaron las entidades seleccionadas con INTERNO_SENAL")
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 7 of 15
BriamR
@ВeekeeCZthanks for your solution is very successful to that part of the requirement.
@calderg1000 Thank you for your interest in the subject, your solution has been very useful to me.
I would only need to solve this part of the publication, thanks for the help provided
Message 8 of 15
john.kaulB9QW2
Z9E3zK5E,
You have a very clean style to your coding. Very nice.
I am just curious.
To be brief, the global variables decl's stick out to me because of the different style. why did you choose this style?
statement return: T
instead of?
(setq *ad-i* (cond (*ad-i*) (1)) )
statement return: 1
another swamper
Message 9 of 15
calderg1000
Regards @BriamR
Here I add the type of signal
  (princ)
  (setq inc 0)
    (setq idd (itoa n))
    (setq efn(vla-get-effectivename(vlax-ename->vla-object enam)))
    (ade_odsetfield enam tn "TIPO_SENAL" 0 efn)
    (setq inc (1+ inc)
          n   (1+ n)
  (princ)
Carlos Calderon G
Message 10 of 15
BriamR
Apparently the lines of the code are in Spanish and that's why it gave me an error, I also told you that when the INTERNO_SENAL field is in data type as integer, the consecutive assignment of internals does not work. Thank you!
Message 11 of 15
calderg1000
Hello, I already corrected it; sorry the translator sometimes plays us wrong
Carlos Calderon G
Message 12 of 15
ВeekeeCZ
@john.kaulB9QW2 wrote:
Z9E3zK5E,
I am just curious.
statement return: T
instead of?
statement return: 1
@john.kaulB9QW2,
thanks.
You made me think about it a little. Not sure whether it is a different style or not, I just consider that as the right tool for the job.
It does what's needed, it's simple, it's clear - it still says (set something default) next to each other, it's clear even for the no-experienced user that he should try this value change to his preference. Also it's not that crowded with parentheses as your cond.
And what's more, it's smart. Someone less experienced might start to wonder... that's weird OR usage...hmm. That happened before.
I simply like it, it's convenient. Good for defaults.
BTW Welcome here to forums! Let's see if you stick for a while with us... to share some clever thoughts 🙂
Message 13 of 15
john.uhden
@ВeekeeCZ
I shouldn't need to remind you of the Kosterian approach.
No need for an (if (and...
A simple (and will do.
For the lurkers, operations within an (and ...) will continue until an operation/evaluation within it returns nil.
John F. Uhden
Message 14 of 15
john.uhden
Actually, one should be more cautious than that.
If N is supposed to be an integer, then..
(or (= (type N) 'INT)(setq N 1))
John F. Uhden
Message 15 of 15
john.kaulB9QW2
I'm glad I made you think about it at least. I consider (or *ad-i* (setq ... different then (setq *ad-i* (cond ... because of what the two statements return. Yes the boole style is less parentheses but I still preferred the COND style because I spent too much time debugging programs where the return types were not carefully accounted for. I'm not saying one is better then the other in every case, just better to acknowledge one style vs the other and their proper uses.
I've seen problem this too much (simplified).
(if (or *ad-i* (setq...
(if (setq *ad-i* (cond...
Thank you for the welcome. Ah, you guys don't need me and I don't have clever thoughts; when I first started in my career I took the SICP course and enjoyed lisp for a few years but after a while I got tired of programming only AutoCAD so I switched to C/C++. I'm just getting back into Lisp again. So I'm very, very rusty.
I've not seen the Kosterian approach (link/writeup?)
This is the type safety side of the coin I'm referring to with the boole type statements (and why I tend to avoid/limit their use). I find the (setq N (cond ... style more readable and dependable and far easier to maintain in the long run.
The above becomes
(setq N (cond
	  (N (eq (type N) 'INT) N) ; -If the value of `N` is set and is
                                   ;  type INT, use it.
	  (2))                     ; -Otherwise set the default value of 2.
which is easier to maintain and easier to read. Again, this type of type safety is a bit overkill but this demonstrates the point I was trying to make about not being diligent with return types nicely.
another swamper
