[LISP] How to read text size in a dimension?
iBlachu
iBlachu
How to read the height of the text in the dimension selected by the user?
I would like the user to indicate the dimension line and the program to read the text height set in it.
ВeekeeCZ
Maybe it's about time to teach yourself how to find such information.
Start with (dumpallproperties (car (entsel)))
Then you have set/getpropertyvalue functions.
Easy-peasy.
iBlachu
Not quite, because in the DXF code of the dimension there is no information about the height of the dimension text, only about the style of the dimension.
ВeekeeCZ
Then use nentsel instead.
paullimapa
of course there is...try:
(getpropertyvalue (car(entsel)) "dimtxt")
Paul Li
IT Specialist
@The Office
iBlachu
And is it possible to read the size of the dimension text in the same way as the following example?
  (if (setq ss (ssget '((0 . "DIMENSION"))))
    (command "_.dimoverride" "DIMSE1" "_off" "DIMSE2" "_off" "" ss "")
Kent1Cooper
No.  That's an editing command that can only impose properties.  The one command that can read properties of things is LIST, but for a Dimension its returned information doesn't include the Text height.
Besides, that code can work with a selection set of multiple Dimensions, since a property like suppression of an extension line can be imposed on more than one Dimension together.  What would you want from such a set by way of reading their Text height, if that might vary?
Your contention in Message 3, if as it seems it's in response to @ВeekeeCZ 's (dumpallproperties) suggestion rather than DXF code information, is incorrect -- see the appropriate property in Message 5.
But you are correct about DXF information -- it's quite unexpected that it does not seem to include the Text height.  If the Text Style used has a fixed height, you could get it from that.  I haven't been able to find where it is stored.
Kent Cooper, AIA
