[LISP] How to check URL exists?
iBlachu
Message 1 of 8
iBlachu
How to check using pure LISP if there is a file with the given name on the server?
Is it possible?
Replies (7)
Message 2 of 8
Sea-Haven
Searching a drive for a single file there is a easy way, you can use the software "Everything" its free and is great to find files. You can run a external shell cmd from Autocad.
Everything - voidtools
es.exe dwgname.dwg -full-path-and-name >d:/acadtemp/dwglist.txt
The dwglist.txt will have all the dwg locations on all drives indexed by Everything.
You need this also Command Line Interface - voidtools
Message 3 of 8
iBlachu
I need a pure LISP (AutoLISP) solution without VisualLisp if possible.
Message 4 of 8
hak_vz
Check this post and solution from @doaiena
What software do you use that you need solution in vanilla autolisp. Without using vl functions solution is impossible.
Miljenko Hatlak
Message 5 of 8
Sea-Haven
What I posted is pure old lisp uses the SHELL command. You do need to download the program Everything it is well worthwhile having finds files instantly compared to explorer that works like 50% of the time.
(command "._shell" "es.exe dwgname.dwg -full-path-and-name >d:/acadtemp/dwglist.txt")
Message 6 of 8
Sea-Haven
Post the page link, it currently goes to all of the posts by doiaena
Message 7 of 8
hak_vz
@iBlachu  Check this solution from @doaiena and my reply to this post about further action needed.
Miljenko Hatlak
Message 8 of 8
Sea-Haven
Hak_vz thanks for update had a look.
Also "How to check where is URL" and then "if there is a file with the given name on the server?" which one is it or both ?
