LISP HELP
LISP HELP
jeguizaASRZM
Message 1 of 1
LISP HELP
jeguizaASRZM
I have found a great lisp that has been created from people of the forum. I was hoping someone can guide me to changing the lisp to my particular task.
I am not familiar with creating or changing lisp so I hope someone can help. I would try and modify it myself with trial and error but I don't really know what lines to start to look at.
The first thing I would like to change the properties of the table. For Example text Size, Column Length, Ext. As if I was inserting a new table with the "Insert table" dialog box.
The Second request would be for that table to update as I change the Polyline. So it would't just keep making a new table but rather have a set table were the Count Column of the block can change based on the Polyline. So for example if I move a vertex or stretch the Polyline and use the command "REGEN" or "REGENALL" the table Count Column would update with the new count inside the Polyline
My Final Idea for modification is for the BCPL routine to have an option to only pick specific blocks based on Block Name or Layer.
Would This be possible?
Any Help, Guidance, Ideas are very Appreciated
Best, JE
Replies (0)
