Lisp Help to Change all Dimensions to Layer Dimension, Color Bylayer, Lineweight Bylayer and Linetype to Bylayer
Hey Fam, i need help with a lisp im trying to put together.
I was able to get the layers portion to work but i cannot seem to get color, lineweight and linetype to all change to bylayer. can someone look at this code for me please. i was able to change it all with line commands but via lisp it wont work for me 😞
(defun c:DL (/ SelectDim)
(setq SelectDim (ssget "X" '((0 . "DIMENSION"))))
(command "._Chprop" SelectDim "" "Layer" "DIMENSION" "Color" "BYLAYER" "LWeight" BYLAYER" "LType" BYLAYER" "")
(princ)
); end of defun
Thanks Fam!!
sorry Fam, i forgot to add the Dim DWG
The DWG show the correct format for this Dim and how they should be throughout my drawing.
doaiena
You just had the quotation marks wrong.
(command "._Chprop" SelectDim "" "Layer" "DIMENSION" "Color" "BYLAYER" "LWeight" "BYLAYER" "LType" "BYLAYER" "")
(princ)
); end of defun
That works! thank you so much!
omg i just realized what you said lol....im a dork for missing the quotation marks...thanks again!
kevin
;Dimensions are influenced by many variables.  Colors start with "DIMCLR" plus one more letter D, T, E, etc.
;Here's my Lisp file/script file below for setting my dims.  The default for bylayer is a period.
 ;* By Kevin McDougall, 1994
;* C:DIMEN command, Sets the following dimension variables.
(command "DIMASZ" "0.14"
"DIMTIH" 0
"DIMTOH" 0
"DIMTAD" 1
"DIMEXE" "0.04"
"DIMGAP" "0.04"
"DIMTIX" 0
"DIMTXT" "0.11"
"REGENAUTO" "ON"
"UCSICON" "ON"
"DIMADEC" 0
"DIMALT" OFF
"DIMALTD" 2
"DIMALTF" 0.3048
"DIMALTRND" 0.00
"DIMALTTD" 2
"DIMALTTZ" 0
"DIMALTU" 2
"DIMALTZ" 0
"DIMAPOST" "m"
"DIMASO" ON
"DIMASZ" 0.11
"DIMATFIT" 3
"DIMAUNIT" 0
"DIMAZIN" 0
"DIMBLK" ""
"DIMBLK1" ""
"DIMBLK2" ""
"DIMCEN" 0.02
"DIMCLRD" 0
"DIMCLRE" 0
"DIMCLRT" 0
"DIMDEC" 2
"DIMDLE" 0.00
"DIMDLI" 0.38
"DIMDSEP" "."
"DIMEXE" 0.03
"DIMEXO" 0.06
"DIMFIT" 3
"DIMFRAC" 0
"DIMGAP" 0.03
"DIMJUST" 0
"DIMLDRBLK" ""
"DIMLFAC" 1.0000
"DIMLIM" OFF
"DIMLTYPE" CONTINUOUS
"DIMLUNIT" 2
"DIMLWD" -1
"DIMLWE" -1
"DIMPOST" "'"
"DIMRND" 0.00
"DIMSAH" OFF
"DIMSD1" OFF
"DIMSE1" OFF
"DIMSE2" OFF
"DIMSHO" ON
"DIMTAD" 1
"DIMTDEC" 2
"DIMTFAC" 1.0000
"DIMTIH" OFF
"DIMTIX" OFF
"DIMTM" 0.00
"DIMTMOVE" 0
"DIMTOFL" OFF
"DIMTOH" OFF
"DIMTOL" OFF
"DIMTOLJ" 1
"DIMTP" 0.00
"DIMTSZ" 0.00
"DIMTVP" 0.0000
"DIMLAYER" "."
"DIMTXSTY" "L120"
"DIMTXT" 0.12
"DIMTZIN" 0
"DIMUNIT" 2
"DIMUPT" OFF
"DIMZIN" 0
"SDI" 0
"psltscale" 1
"DYNMODE" -1
"wipeout" "f" "off"
"SELECTIONCYCLING" 0
"UCSDETECT" 0
"ORTHOMODE" 0
"DYNMODE" 0
"ROLLOVERTIPS" 0
"SAVEFIDELITY" 0
"QPMODE" 0
"SNAPMODE" 0
"SELECTIONPREVIEW" 0
"PROPERTYPREVIEW" 0
"ANNOALLVISIBLE" 0
"annoautoscale" 0
"textstyle" "L120"
);command
(prompt "\nStandard dimensioning style set.")
(princ)
