Okay, its been about a week since I started dipping my toes into learning/applying lisp and I feel like I'm starting to be able to understand what's written but I'm still not confident in coding something like this to do what I want it to.
To get to the point, I found a lisp on these forums written by BTK back in 2017 that I made some changes to that draws what we call muntin bars (mullion? mullions?) it doesn't *really* draw the bars per say but the lite pattern that results from whatever configuration you are going for. So far, so good. However, I find myself wondering if I can add an IF function that will draw the offset for a profile or stops with 45 degree miters in the corners of each lite, and at the same time ditch the "frame offset" that gets called up first completely.. Or in the name of possible functionality at least make it so I can enter a value of 0 for no offset.
I have attached a sample drawing and the lisp file in question showing what it is I'm trying to accomplish and have left a plethora of notes in the lisp trying to understand what its doing. I would be perfectly happy to be coached in the right direction of writing it myself, or just having a finished product with a brief explanation on what's new. Any help is welcome (and needed), Thank you!
