Hi folks, ![]()
I have an problem where i export drawings daily with (simple script) to change settings but theres one thing i can't solve, which is very time consuming. Deleting stuff that is"temporary things" in my drawings.
1. Is it possible to make an lisp that search an txt.doc or other file-extension for layer names and deleted all layers listed in this specific file, "no matter if its blocks or objectives or other things under this layer in the drawing".
2. If not: mby its possible to delete all layers including name "XXX-Building-B" while there might be 1000 layers named "XXX-Building-B-XXX" to do directly from the lisp routine
I would personally prefer something like an text doc so other ppl can edit the list fast.
If u have any ideas or inputs plz add them
/ Regards A
