lisp - getpoint geometric center of last entity
nmckelveyHMN4X
nmckelveyHMN4X
As per the above. Looking for a little help with a lisp routine.
I have to routine running that draws a region and the next step I am looking for is to set a point  as the geometric center of that region so I can use that value in the next stage of the routine. Any help for this line of code would be appreciated.
(SETQ p3 (getpoint ……"gcenter"……."last"...???
Thanks in advance
dbhunia
Check >>THIS<<
Or if your last object is a "REGION" then try like this...
(setq P3 (vlax-get (vlax-ename->vla-object (entlast)) 'Centroid))
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
nmckelveyHMN4X
Thank you so much.
Worked perfectly!!
Kent1Cooper
If it's a closed Polyline or Spline:
(setq p3 (osnap (vlax-curve-getStartPoint (entlast)) "gcen"))
[That's assuming there's nothing else with a geometric center around that it could snap to instead, when "picked" at the object's start point.]
You will need to do this first, if not done already, to get that (vlax-curve...) function:
(vl-load-com)
Kent Cooper, AIA
Michiel.Valcke
(vl-load-com)
@Kent1Cooper
I'm sorry to restart an old post, but this might be a solution to a problem I'm currently facing. However, the part in my routine tries to get a list of handles and their corresponding geometric centers, so there will always be a lot of other objects to snap to when "picked" at the object's start point. Would turning off osmode sysvar help?
Kent1Cooper
@Michiel.Valcke wrote:
....the part in my routine tries to get a list of handles and their corresponding geometric centers, so there will always be a lot of other objects to snap to when "picked" at the object's start point. Would turning off osmode sysvar help?
If you're calling for a specific Osnap mode, that would override any running mode(s) that you have set, so I think if it's not getting the geometric center of the object you want, turning OSMODE off probably would not help.
Kent Cooper, AIA
john.uhden
Hmm.  2002 doesn't have a "gcen" snap.  That's cool.
John F. Uhden
